General Diesel Discussion
20W50 oil...
Old May 23, 2013 | 03:29 PM
parkland's Avatar
parkland
20W50 oil...
Just throwing this out there.....
Has anyone ever heard of newer diesel engines running on thicker oil than factory spec ?
As the power per displacement ratio goes up and up.... wouldn't it make sense to use a heavier oil to reduce wear?
Old May 23, 2013 | 09:39 PM
therifleman556's Avatar
therifleman556
Actually, they're going the other way. 5W-40 and 10w-30 are making their way into class 8 engines....
All about fuel economy. Today's synthetics make 15W-40 a bit overkill.
Old May 23, 2013 | 11:50 PM
Ford_Six's Avatar
Ford_Six
Don't run thicker oil than needed. The thicker oil cannot flow into tighter tolerances, and will starve bearings. Also, there are higher pumping losses, and the filter bypass will open more often.
Old May 24, 2013 | 01:00 PM
parkland's Avatar
parkland
Yes, I read this is true on some engines.
I was reading a bunch of stuff to do with car manufacturing, and it seems like common practice to use lighter oil, and reduce engine lifespan in the name of fuel economy. More and more light oil use is to improve MPG, reducing engine lifespan.
I was just thinking it's almost crazy that diesel engine oil is almost the same as 20 years ago, and power output is about double.
Old May 27, 2013 | 12:27 AM
04badford's Avatar
04badford
Its more for the Injector realiability thick oil is hard on the Injects
Old May 27, 2013 | 07:48 AM
therifleman556
Only on HEUIs
Old May 27, 2013 | 06:39 PM
Ford_Six's Avatar
Ford_Six
The additives in the oils have changed a lot in the last 20years-
Diesels are really gentle on the bearings. While the compression is higher, the speeds are lower, bearings larger and the combustion event is spread over nearly four times the crank rotation as on gas engines (20* vs 5 or so).
Old May 29, 2013 | 10:43 AM
parkland's Avatar
parkland
Sure, but with 6.4's and 6.7's having more metals in oil samples than 7.3's, it's pretty obvious that the newer engines are pushing the envelope as to how much stress the same oil will hold...
TimWaite
Modular V10 (6.8l)
Jan 18, 2016 10:26 PM
mabc926
31
Sep 19, 2010 02:04 PM
Schmitty133
Jan 3, 2009 09:27 AM
caterpillar
Oct 22, 2006 07:19 PM
RynL88
Feb 21, 2005 08:35 PM
