Modular V10 (6.8l)
Oil additives ?
Old Jan 9, 2016 | 10:53 PM
TimWaite's Avatar
TimWaite
Oil additives ?
I've never been one to add any sort of additive to my engine oil. My brother in law is starting to use Hot Shots in my sisters 6.0 diesel. He is also going to use a different type (same manufacture) for his gas car. I use power service diesel kleen in my tractor. While I was getting the oil changed in my company van (gas), I asked them about Lucas h.d. oil stabilizer that they had displayed. They said it was a good product and use it. I've run full synthetic in all of our gas vehicles and have had good luck. What are your thoughts? My v10 has about 85000 miles
Old Jan 10, 2016 | 06:57 AM
JWA's Avatar
JWA
Modular Motors are designed to use a specific viscosity oil, adding anything to increase that in hopes of "improving" longevity is not beneficial. Regardless what a diesel engine owner uses or what the "jiffy lube" crooks tout and over charge for these engines tend to be very long-lived when simply following Ford's recommended procedures.
A good quality oil, equally good filter, frequent level checks and changes not exceeding 5K miles will keep these engines running at least 275K miles.
Old Jan 10, 2016 | 08:40 AM
TimWaite's Avatar
TimWaite
I agree with the good quality oil and regular intervals. I do my own oil changes to. My question was more curiosity then anything. I've always been a little skeptical of " add this to your oil and gain 200% more power and blah, blah, blah"
Old Jan 10, 2016 | 08:04 PM
dkf's Avatar
dkf
Got an air cooled lawn mower with a "slinger" that throws oil on the bottom end? That is about the only good purpose for the Lucas oil stabilizer. And you only add a little. Lucas can actually make oil foam and cause all kinds of problems. For the most part it is a solution to nonexistent problem, we have different weight/viscosity oils for a reason.
Old Jan 11, 2016 | 06:55 AM
JWA's Avatar
JWA
Oh, certainly when I was new to Modular Motors--a beat to hell '97 E250 w/5.4----I had to unlearn everything I knew about earlier motors of any badge. Running 10W-40 with something like Lucas was the thing to do---and seemed to work fine.
Its good to ask---IMHO nothing so good as talking with those who've "been there, done that".
Old Jan 11, 2016 | 12:15 PM
AllAboutDaZ's Avatar
AllAboutDaZ
I have used Lucas before on my v10 and have not had any issues with it. I guess people have mixed feelings about it
Old Jan 11, 2016 | 04:34 PM
hodge5's Avatar
hodge5
I agree.
While I generally like Lucas products, I did have a negative experience with the oil additive in a 12 valve Cummins. It made the lifters noisy- enough that my daughter heard it, and she isn't highly sensitive to engine noises. I changed the oil, without adding any Lucas back, and it went away.
I do like it in differentials.
Old Jan 18, 2016 | 10:26 PM
pappy19's Avatar
pappy19
Any oil questions, go to Used Oil Analysis - Bob is the Oil Guy - Bob is the Oil Guy. , the premier oil Web site.
sand_fiend
Oil & Lubrication
15
Jul 11, 2011 04:46 PM
ronjon95
Apr 6, 2009 08:16 PM
1nascar24fan
Oil & Lubrication
Nov 26, 2006 08:15 AM
sleepy127
Aug 23, 2006 05:36 PM
bad ass diesel
Nov 5, 2004 06:05 AM
