Hey guys, just wondering if anyone knows where I can get a good anti-foaming agent for oil, preferably online. This is not only for my truck but for my pullin tractor. Many thanks!
the only disel oil additive that i know of is made by Power Service. I have been able to find this stuff at big truck stops, some Wal-Marts, and some NAPAs.
Diesel engines require engine oil to remove more combustion by-products than gasoline engines. The oil contains an additive package to accomplish this job, however over time, these additives become depleted and ineffective. Diesel Lube® Oil Extender replaces the additives in diesel engine oil to provide the extra protection required between engine oil changes.
# Replaces the detergents, friction-modifiers and anti-wear additives depleted between extended oil changes
# Provides extra protection during high-temperature, high-load operations
# Protects against thermal and viscosity breakdown
# Reduces valve and piston-ring sticking - decreases oil consumption
# Disperses soot to reduce sludge formation in engine oil
# Reduces engine wear during cold starts
# Does not contain any alcohol of any kind
honestly, if you use a high quality oil that is full diesel raited, you shouldn't have a problem
hey thanks for the reply and for diggin that up. Honestly I really need it for the hydraulic oil in my pullin tractor, however also trying to solve an erratic runnin psd, oil related, maybe aeriation, just narrowing down the possibles,, thanks again
