Sponsored by: Real Truck
Quick leveling question
Old May 21, 2013 | 10:37 AM
bthr22's Avatar
bthr22
I'm planning on doing a 2" level. Will I need a drop pitman arm, or can I stick with the stock pitman arm? Will I need anything else? I plan on doing the level when I replace my coil springs and shocks. (I have another thread on that).
I'm driving a 2000 F250 V10 2WD CC SB (twin I-beam front axle) if that info is pertinent to this question.
Thanks!
Ryan
Old May 21, 2013 | 11:43 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
You might need dual Axis camber bushings to fix the alignment. And you might need to massage the C and knuckle a little with a grinder.
https://www.ford-trucks.com/forums/8...periences.html
Here's an install thread:
https://www.ford-trucks.com/forums/1...kit-is-on.html
Old May 22, 2013 | 10:25 AM
bthr22's Avatar
bthr22
Thanks Texas tech!
wfilkins47
May 14, 2015 11:51 AM
ravens fan
Jul 9, 2013 07:02 AM
xc4jokestomper
13
Sep 8, 2012 11:14 PM
dtingle89
Nov 12, 2009 05:15 PM
Muktown
Sep 16, 2006 02:33 PM
