Driveability Issues After Leveling kit
Old May 12, 2015 | 11:14 PM
wfilkins47's Avatar
wfilkins47
Hi everyone, have a 1993 F150 extended cab I recently put leveling springs on. I used Pro Comp 2" lift springs (#24212), and the truck now sits dead level. I am having some driveability issues including wandering, a little bit of bump steer, and the steering wheel not returning to center during turning. This is after an alignment at a local shop, and some additional adjustments at home.
Here are some more details:
After the spring install i took it to an alignment shop and they got it close but said they couldn't get it perfect without drop brackets. I looked at the bushings they installed and noticed they only put in 2.75 degree bushings, so I installed 3.25 degree adjustable bushings and used their numbers to theoretically get the Camber to 0.5 degrees per side and left caster at 2.3 degrees and right Caster at 2.9 degrees. These are my calculated numbers although I havent gotten them checked by a shop.
I am thinking that the lack of positive caster is the source of most of my issues. Anyone have any input on that?
If I need more caster it seems like I could get it by doing either radius arm drop brackets or axle pivot drop brackets. Can I do one without the other? And if I can which one would everyone recommend, i.e. which is stouter. I have read (on this and other forums) of radius arm drop brackets sometimes resulting in cracked frames.
Thanks for the help.
Old May 13, 2015 | 09:23 AM
hotrod351's Avatar
hotrod351
installed the same springs, took it to the alignment shop, never had any issues. sounds like the shop you took it to doesnt know what there doing.
Old May 13, 2015 | 10:33 AM
rugermack's Avatar
rugermack
Do a tie rod flip or drop pitman to get rid of bump steer.
Old May 14, 2015 | 11:51 AM
wfilkins47's Avatar
wfilkins47
Yea i'm pretty sure these guys are either ignorant or just lazy. Do you happen to know what your caster wound up being after you installed the springs?
Thanks. I have heard something about the tie rod flip but need to do more research.
Anyone else have any input on doing either radius arm drop brackets or axle pivot drop brackets?
ravens fan
Jul 9, 2013 07:02 AM
lilmatt119
Mar 28, 2013 03:08 PM
xc4jokestomper
13
Sep 8, 2012 11:14 PM
jbirdsvt
Mar 6, 2007 08:48 PM
WhëëlMå1
1978 - 1996 Big Bronco
May 10, 2003 10:51 PM
