Sponsored by: Real Truck
srw or drw
Old May 20, 2013 | 08:22 PM
rc.chris's Avatar
rc.chris
srw or drw
Looking at getting a big toy hauler, 14500 lbs dry weight and 18000 lbs gvw and a 3000lbs hitch weight. Looking at a couple of 07 f350's, one srw and drw. Which one is going to be the best choice? I like the looks of the srw better but not sure if it will handle it.
Old May 20, 2013 | 08:33 PM
jdadamsjr's Avatar
jdadamsjr
IMHO?
it won't --- (at least not legally nor safely )
and for that old a truck, the dually might not - I'd look closely at the specs for both trucks before I dove in....
https://www.fleet.ford.com/showroom/...07_default.asp
good luck...
Old May 20, 2013 | 09:04 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Decide your needs, then pick a truck, dont pick a truck and then make excuses to make it work. You should get a DRW.
Old May 21, 2013 | 06:37 AM
redford's Avatar
redford
FTE Leadership Emeritus
Here is the 2007 Ford towing guide:
https://www.fleet.ford.com/showroom/...trp17Aug06.pdf
Your well out of the prudent towing range of an SRW truck. That heavy of a trailer really needs a 2008+ F-450.
Old May 21, 2013 | 08:31 PM
Ferguson65's Avatar
Ferguson65
3k of pin and 18,000 total is definatly dually territory. You'll be over rear axle and GVW in no time with that heavy of a trailer on a SRW truck. Ford only rates the current SRW truck to around 16K, IIRC.
Old May 21, 2013 | 08:43 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by redford
H.... That heavy of a trailer really needs a 2008+ F-450.
A 2000 F-450 will also handle that size load quite well.
Old May 21, 2013 | 10:23 PM
redford's Avatar
redford
OK, good point.
Old May 22, 2013 | 10:36 AM
rc.chris's Avatar
rc.chris
Thanks for all the info!
Old May 22, 2013 | 10:44 AM
fordman19762003's Avatar
fordman19762003
IMO you're over 350 territory, you need a 450.
PrinceValium
Oct 12, 2016 10:33 PM
nwatkins176
May 16, 2014 04:53 PM
roadkingfl
6.7L Power Stroke Diesel
Jul 7, 2010 03:12 PM
69_bronco
Jul 22, 2005 09:45 AM
sstarnes
All Things Towing
May 4, 2004 06:42 AM
