grinding when shifting to second
Old May 19, 2013 | 11:11 PM
1992FordF150Custom's Avatar
1992FordF150Custom
Exclamation grinding when shifting to second
my 92 f150 5-speed has been making a rattling noise for a few months now but it still worked fine. when i put the clutch in it stops so must be tranny, would it be a bushing or bearing? just recently it grinds when i put it it 2nd gear mostly when i downshift and once in a while it will grind the slightest in 3rd, do you think these problems are relate or different?
Old May 20, 2013 | 08:36 AM
1992FordF150Custom
any ideas guys?
Old May 20, 2013 | 09:01 AM
blue924.9's Avatar
blue924.9
how many miles on it, sounds like wore syncros to me(at least the grinding does)
Old May 20, 2013 | 04:06 PM
1992FordF150Custom
348,000kms on the truck, it doesn't grind only if i slow right down
Old May 20, 2013 | 04:13 PM
blue924.9's Avatar
blue924.9
what do you mean if you slow right down?
Old May 20, 2013 | 04:57 PM
Brian085's Avatar
Brian085
Mine has a little grind going first to second also. I wonder if any chance the line needs to be bled from the slave since I replaced the master cylinder, I only pumped it up and went on my way.
Also, How does one inspect the syncros? I have my top cover off the trans to replace those three back seals so that would be the best time, I'd hope.
Old May 21, 2013 | 07:44 AM
blue924.9's Avatar
blue924.9
yes you need to have it apart to inspect them, also just look for anything worn in general
Old May 21, 2013 | 09:43 AM
1992FordF150Custom
if i slow right down to downshift it doesn't always grind
Old May 21, 2013 | 07:52 PM
1992FordF150Custom
do you think its just the syncros or is something else wrong?
Old May 22, 2013 | 07:51 AM
blue924.9's Avatar
blue924.9
yeah sounds like syncros, or it could be your driving, try shifting faster or slower when you shift.
Old May 22, 2013 | 11:11 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
If you don't see noticeable wear or chipped teeth, you may be able to smooth up the shifting and milk some more life out of your trans with some proper manual trans fluid.
Since you have an M5OD, its important to keep the fluid thin for the splash lube design. What you want is a quality MTF/Syncromesh like Pennsoil-syncromesh, Amsoil manual syncromesh transmission fluid, or Redline manual transmission fluid.
THese fluids have a similar viscosity to to ATF to keep the M5OD happy, but have much improved anti-wear additives, and the proper friction modifiers for yellow metal syncros like you have. ATF is very slippery and is not helping your syncros do their jobs.
I have switched my ZF5 over to Pennsoil syncromesh, and now redline, and the shifting is soooooooooooooooooooooo much better now.
Romulus
Jul 16, 2018 10:10 AM
White_Knuckles
19
Jan 11, 2010 12:49 AM
sully75
24
Mar 5, 2009 01:10 AM
snipa
Sep 30, 2005 11:10 AM
BetsyBlue79F150Custom
Feb 26, 2003 08:21 AM
