what's a bad synchro??
Old Apr 11, 2011 | 08:45 PM
Romulus's Avatar
Romulus
I have the ZF-6 6 speed manual transmission in my 99 F-250 with PSD..a whirring noise just started when I shift from 1st to 2nd, 2nd to 3rd but goes away at the higher gears, 3rd to 4th and 4th to 5th..it only happens when I move the stick..is this a synchro problem? Shifts are still smooth and no gear grinding..yet. Any advice would be greatly appreciated.
Old Apr 12, 2011 | 12:16 AM
jt's F-250's Avatar
jt's F-250
does it ever try to get stuck in gear or does it slip out of gear
Old Apr 12, 2011 | 12:22 AM
SpringerPop's Avatar
SpringerPop
Throwout bearing making noise? Pilot bearing?
Those are a couple of things it could be.
What's the level of lubricant?
Pop
Old Apr 12, 2011 | 04:17 PM
Romulus's Avatar
Romulus
Gears hold - no random popping out or getting stuck; no slipping of clutch - the clutch moves in/out with no problems and only about 40K miles on current clutch assy (TO &pilot bearing, Pressplate etc). In my sleep I was thinking lubricant --- that's reaching 70K miles, but no signs of leaks - it could be just plain worn out. That will be the next step to change fluid out this evening. Thank you gentlemen for your thoughts and replies.
Old Apr 12, 2011 | 07:59 PM
F350-6's Avatar
F350-6
A worn synchro will cause the gears to grind when shifting. When does the whirring noise happen? Does it do it if you accelerate and then just hold the clutch in and not shift? Shift into neutral and coast instead? Do it on downshift between the same gears?
Let us know if the fluid change helps or fixes it.
Old Apr 17, 2011 | 10:44 PM
Romulus's Avatar
Romulus
Well alright - changed the fluid out and..it was low...really low. The noise from shifting went down a bit but is still there. I would've posted earlier but recuperating from selling my kidney to fill the ol diezl tank..ugh. I'm taking the advice posted many times before and will drive the old girl until she tells me no more. Everything works normally, just a short whine when shifting the stick from 2nd to 3rd. Thanks again for the advice and your smarts. Hooo-rah.
Old Jul 16, 2018 | 10:10 AM
Yo Clyde's Avatar
Yo Clyde
Could be a universal joint?
Sounds like it could possibly be a u-joint making the noise.
echristiansen
Mar 24, 2017 11:58 AM
tndallas
16
Feb 6, 2017 12:50 PM
Jacob Lowell
Nov 30, 2016 08:10 PM
tananaBrian
Oct 9, 2015 05:51 PM
RDavis
Dec 21, 2007 04:52 PM
