1356 Transfer Case Questions
Old May 18, 2013 | 07:51 PM
thejermsr's Avatar
thejermsr
I recently pulled my Borg Warner 1356 Electric transfer case out of my 1991 F150. It works fine but was leaking terrible. I purchased a gaket/seal kit online and will be installing myself. I pulled the rear housing off removed the speedo gear and the snap ring off the shaft to pull the case apart. As I pulled it apart things moved and I did not get a good look at all as to how the gears were sitting on the motor shaft. I have been dry fitting the case back together and can not seem to get the shaft to come out the rear half of the case enough to be able to put the snap ring back on. I am sure I just didnt put this back together right or am overlooking somethig but not sure. How does this all go back together? Help and thank you
Old May 24, 2013 | 02:28 PM
skyfox10's Avatar
skyfox10
Not sure if this will help...
1983 Ford Bronco Diagrams picture | SuperMotors.net
powerstroker100
28
Jul 17, 2010 05:23 AM
prestroke diesel
Oct 22, 2008 12:25 PM
$Simpleman76
Apr 14, 2007 11:50 PM
03XLT4x4 Flareside
Dec 21, 2004 08:47 PM
nike_z
Mar 26, 2003 03:33 PM
