divorced transfer case
Old Apr 14, 2007 | 09:52 PM
$Simpleman76's Avatar
$Simpleman76
what is meant by a divorced transfer case
thanks
Old Apr 14, 2007 | 10:01 PM
m000996's Avatar
m000996
A divorced transfer case is physically separated from the transmission by a drive shaft. In a divorced transfer case setup there will be three drive shafts:
1) One shaft leading from the transmission to the transfer case
2) A separate shaft running from the transfer case to the rear end
3) A third shaft running from the transfer case to the front end
An integral transmission/transfer case is all one unit. It will not have a visible, external shaft linking the transmission and transfer case.
Old Apr 14, 2007 | 10:50 PM
Franken-Truck's Avatar
Franken-Truck
It means its sad now and will be facing hard times for the near fututre, but is better off in the long run
Old Apr 14, 2007 | 11:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
Try the transfer case forum...
Ford Fan
Feb 21, 2014 09:10 PM
176ford
Apr 15, 2004 09:05 PM
Big Bad 1Ton
Jul 12, 2002 02:30 AM
larbuck
Nov 29, 2001 01:08 PM
Ken Kennedy
Sep 3, 1999 06:51 PM
