Trouble starting
Old May 17, 2013 | 10:40 PM
Mkmw522's Avatar
Mkmw522
Trouble starting
I have 03 6.0. When the truck is cold it will start right up. The truck warms up it won't start. It has no oil rings leaking. New high pressure oil pump and a new ICP.
Old May 18, 2013 | 04:41 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old May 18, 2013 | 06:54 AM
bismic's Avatar
bismic
To troubleshoot properly, you will need a scan tool (ScangaugeII, Dashboss, TorqApp, etc). Scangauge is around $150.
Need:
ICP volts
ICP pressure
IPR % duty cycle
FICM M Power
FICM V Power
FICM L Power
FICM Sync
Cam/Crank Sync
Just a curiosity - how do you know that there are no high pressure oil o-rings / d-rings leaking.
Old May 20, 2013 | 03:04 PM
Tugly's Avatar
Tugly
Give this a click: [LINK] That, plus a scan tool of some sort can point the way... or you can throw darts at parts 'til it starts.
Old May 20, 2013 | 03:37 PM
Maxium4x4's Avatar
Maxium4x4
Cold it will start, No start when Hot usually indicates an oil leak somewhere in the system.
danjl13
May 27, 2015 10:16 PM
Number21
Mar 20, 2014 08:32 PM
DaveO1990
General Diesel Discussion
Apr 8, 2013 07:29 AM
rado
Jun 22, 2011 05:08 PM
soup2nutz
Nov 25, 2006 05:34 PM
