6.0 Excursion Power Stroke run problem :( !?
Old Jun 21, 2011 | 10:36 AM
rado's Avatar
rado
Old Jun 21, 2011 | 01:58 PM
Maxium4x4's Avatar
Maxium4x4
The experts will be along who know the readings, just listening I vote... FICM Any previous history of work performed? Battery voltage looked low at start in the first vid or I wasn't looking at the right thing. Never been around the scan gauge ever.
Old Jun 21, 2011 | 02:03 PM
embry1123's Avatar
embry1123
Compare your actual HPOP oil pressure with desired oil pressure. I don't use/have that particular guage (I use the AutoEnginuity) but it appears that your oil pressure (high pressure) isn't going high enough and is also falling too low?
Old Jun 21, 2011 | 06:09 PM
cheezit's Avatar
cheezit
seems like injector stiction to me.
Old Jun 22, 2011 | 03:34 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Hey Cheezit,
The SYNC that was showing, if that was Cam&Crank sync, and it was Not sync-ed,
How does a motor run when these are not in sync.
Just curious. Would that cause His rough running?
Old Jun 22, 2011 | 04:45 AM
rado's Avatar
rado
^It amazes me, too
where the cam and crank sensors?
Picture?
Sorry bad english.
I'm north of the country
Old Jun 22, 2011 | 05:04 AM
bismic's Avatar
bismic
Crankshaft sensor (CKP)
Ford Truck Enthusiasts Forums - bismic's Album: Miscellaneous Sensors - Picture
Camshaft senor (CMP)
Page 10: Component Locations
Page 53: Electrical Components
I doubt that either of these senors are your issue though.
Is your oil fresh, and new Motrocraft filter? What oil are you using?
I vote for you trying a product caled Rev-X if it is an issue w/ injector stiction.
Old Jun 22, 2011 | 05:57 AM
npccpartsman's Avatar
npccpartsman
Stiction and the voltage seems low to me at start also.
Old Jun 22, 2011 | 06:18 AM
rado's Avatar
rado
Teboil HPD 5W-40 CI-4 api oil.
New oil filter (i don`t characters :/ )
Why the crank and cam is not synchronized ?
Old Jun 22, 2011 | 06:19 AM
rado's Avatar
rado
Also video 2? Video 2 is the new batteries...
Old Jun 22, 2011 | 06:35 AM
npccpartsman
No. Video 2 is OK but in video 1 battery voltage was fairly low on start up at 10.9. Crank/cam sync would only be a concern if the truck wasn't starting.
If the truck runs better after it warms up then injector stiction would be your problem. The FICM voltage appears to be good.
Old Jun 22, 2011 | 06:46 AM
rado's Avatar
rado
not the crank and cam sensor timing may be wrong though it states in the engine?
which adjusts the timing of those?
Old Jun 22, 2011 | 12:42 PM
rado's Avatar
rado
What scangauge FVP mean?
Ficm incoming voltage? Which decreases the voltage of 2V with a cold, it will pikkuhiljaan 12V? Annealing of? Why does the voltage min. 2V only the first? Ficm broken?
Old Jun 22, 2011 | 05:08 PM
cheezit's Avatar
cheezit
you only need ckp and cmp timed to start. after that the truck will still run if it drops ckp
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
