Water Pump Problems
Old May 17, 2013 | 04:56 PM
El Camino Man's Avatar
El Camino Man
Water Pump Problems
Hey guys. Im knee deep trying to remove my water pump. I got a loaner tool from the local auto parts store to remove the nut on the fan. Only problem is, the nut is tighter than my fan belt (i.e. it slips before the nut loosens). Iv tried whackin it with a hammer, iv tried wrapping a ratchet strap around the pulley, nothing works. Any ideas?
Old May 17, 2013 | 05:08 PM
glovemeister's Avatar
glovemeister
You are going LH thread direction right?
Old May 17, 2013 | 05:12 PM
El Camino Man
As in turning it like im tightening a normal bolt? Yes. If your looking at the engine, I turn to the right. The fan says right hand threads though, not left
Old May 17, 2013 | 05:38 PM
glovemeister
Here is a good document that may help you :http://www.thedieselstop.com/faq/949...e=stjs73br.htm
Old May 17, 2013 | 05:39 PM
427 fordman's Avatar
427 fordman
Turn to the left (counterclockwise when looking at it from the front. Its normal thread.
Old May 18, 2013 | 08:02 AM
El Camino Man
Finally got it off there! To anyone reading this thread in the future:
You need a special tool you can get (and usually rent) from any auto parts store. It will include a handful of what looks like very large wrenches and some that look like the wrench end is a square (imagine the grapple on the stuffed toy games at WalMart). Once you get the tool, youll know what Im talkin about...
You need to use them BOTH. The wrench goes on the threads, the square one on the 10mm bolts holding the water pump pulley on. The square one needs a 1/2" ratchet or breaker bar. I used a breaker bar AND cheater pipe and it still took all I had to get it to move and Im a pretty built guy.
If you have a buddy, utilize him!!! Put a cheater on both wrenches and pull like heck! I was alone so I use a ratchet strap tied to one wrench and me pulling on the other. Use your imagination! It worked!
Once you start to remove your water pump, KEEP TRACK OF YOUR BOLTS. Theyre different lengths. I left them in the holes when I removed the pump and tried not to tilt it. If you have any questions about removing your water pump while its still fresh in my head, ask away!
Old May 18, 2013 | 10:49 AM
DarkStarMedia's Avatar
DarkStarMedia
I hope you are putting on an international pump with the filtrr....
richard
Old May 18, 2013 | 01:32 PM
Hussler's Avatar
Hussler
Make sure when re-installing the fan to wrench it down tight. There have been a few on here who did not tighten it enough and when shutting the engine OFF the fan spun off the threads and went through the radiator.
Old May 18, 2013 | 01:35 PM
El Camino Man
I put the old pump back on with a new gasket. Fixed the problem!
And I made sure to put the torque on it when wrenching it down. If that dern thing comes off, Ill be both mad and amazed lol.
Old May 18, 2013 | 10:41 PM
oldbird1965's Avatar
oldbird1965
richard
Did you???
Old May 19, 2013 | 03:59 AM
stainlessstroker95's Avatar
stainlessstroker95
Glenn, did you get the new pulley and bolts from international when you did yours? Holy crap that was high.
Old May 19, 2013 | 06:52 AM
fordman67's Avatar
fordman67
Or at high rpm let off fuel fast...yea.i have e-fans and a new rad...becha can't guess y?
Old May 19, 2013 | 07:32 AM
oldbird1965
I used the same pulley and only had to get a couple of new bolts from Lowe's
Old May 19, 2013 | 09:54 PM
stainlessstroker95
Really. Well crap i ordered the bolts and pulley from international already. Guess i will be returning it now.
Mad1966man
2009 - 2014 F150
Jul 28, 2017 08:17 AM
00f250sd
Aug 11, 2009 01:06 PM
gneill794
Oct 25, 2008 08:45 PM
NS F250
18
Jul 22, 2007 11:15 AM
1poorboy69
Sep 18, 2005 12:54 PM
