2003 6.0L water pump pulley broken
Hi All,
The water pump pulley on my 2003 excursion has broken! I ended up having to remove the whole assembly fan, water pump pulley and water pump as one unit. I put a cutting wheel on my grinder and removed the borked pulley. I used a chain wrench and a fan nut wrench to remove the fan (that was a PITA). I replaced the water pump, water pump pulley and the drive belt. I have spun the fan back on, but there's no room to torque the fan nut down ... is there a trick to tightening the fan nut?
TIA,
George.
TIA,
George.
Hi All,
TIA,
George.
TIA,
George.
I borrowed the tool from Autozone. If you check with them they might have one. Caution there are 2 sizes. and only the 1 7/8" will fit your truck.
The way to remove the water pump is to use the special tools/wrenches to remove the fan. Then you can remove the pulley and the water pump.
Best of luck
Vettdrv,
I actually bought the fan nut wrench (and a chain wrench). I have already removed the fan nut. My problem is on the installation. I can get the fan nut wrench on, but there's literally no room to turn the wrench when it's placed on the fan nut.
I have installed in this order,
1. water pump
2. water pump pulley
3. drive belt
4. fan shroud support
5. the fan
#4 is in the way whether it's bolted on or hanging loose. is there something I am missing?
Thanks,
George.
1. water pump
3. drive belt
5. the fan
Thanks,
George.
Vettdrv,
1. water pump
3. drive belt
5. the fan
Thanks,
George.
1. water pump
3. drive belt
5. the fan
Thanks,
George.
This was the only way to get it. I also had to use a box wrench as a semi extension to get enough leverage to tighten the nut.
It was a two person job,, but with enough !##$#@! I was able to get it on and tightened.
I just did my WP last week on my 7.3. I had to secure the shroud. Then install the fan. The wrench was a very thin wrench. The wrench to hold the pulley was not a chain wrench but one that is about 1/8" thick and holds on to the bolt heads that secures the pulley to the waterpump.
Well, I finally got it!
I am not sure what it's called, but I'll call it the fan shroud support. After I put the fan on I was able to unbolt the fan shroud support and wiggle it around for just enough room to tighten the fan nut. I had to tighten it from underneath .. and yes you are right it was a 2 man job ... what a PITA. Thanks for your advice!
Lee Binder
Aerostar
06-26-2020 04:05 PM
Groundpounder0331
08-19-2015 10:59 AM
