the kits?
Old May 19, 2013 | 12:09 AM
speedwrench72's Avatar
speedwrench72
she will run like swiss watch ifin you go wit racins injectors!! Racor makes a 2 micron fuel filter u might think about....PF 829B
Old May 21, 2013 | 09:14 AM
Fordidipower's Avatar
Fordidipower
Well just wanted to report without starting a new thread. Changed the timing on my pump back to stock ( matched up the lines) and it stopped the noise for about 3 miles then came back. Also it now has a gray/white smoke condition. So bad injectors right? Thanks guys you have been a lot of help
Old May 21, 2013 | 01:10 PM
Red454sedgwick's Avatar
Red454sedgwick
All those lines tell you is that the pump is in the hole straight, you time it right you need a timing light with the part for the diesel
Old May 21, 2013 | 01:36 PM
Fordidipower
Hmmm well then the pump is in the hole strait ha. But like I said the knock went away but came back. So new injectors is my next step unless there is anymore ideas
Old May 21, 2013 | 03:45 PM
xcite's Avatar
xcite
Kind of, the marks are there so that during assembly the pump will be close enough in timing to be able to start it and then timing can be set correctly from there.
jnldr
26
May 22, 2010 09:08 AM
ksmith203
Oct 3, 2008 11:18 AM
PastorErin
Apr 20, 2007 11:42 PM
fordboy_52
16
Apr 16, 2006 08:33 AM
urban farmer
Jan 12, 2003 05:39 AM
