2001 no start
Old Jun 1, 2013 | 08:21 PM
  #31
maxtruck00's Avatar
maxtruck00
I did drain some from the fuel bowl, had a red tint and smelled old, but nothing to bad. I just don't know what else it could be? good rail pressure, good buzz test. whats left?
Old Jun 1, 2013 | 08:25 PM
  #32
carltonwebb's Avatar
carltonwebb
https://www.ford-trucks.com/forums/a...9&d=1365679112
TUGLy lists that in his signature. It may help with values u seek. Red fuel prob means job site tank and they are notorious for water in them around here. When i drained mine, I removed the power wwire from the pump, ran a hot wire, installed a hose to the filiter drain and drained all it would pump. Once i put some fresh fuel in it, I had to crank a couple minutes to get the new fuel through the system.
Old Jun 1, 2013 | 08:53 PM
  #33
maxtruck00's Avatar
maxtruck00
i'm pumping the tank now..it looks more brown than red.
Old Jun 1, 2013 | 09:47 PM
  #34
maxtruck00's Avatar
maxtruck00
thanks for that paperwork! under "Requirements to start" it says i need 1 to 6 milliseconds of fuel pulse width. I have .5 MS It seems thats the problem?!
Old Jun 1, 2013 | 11:34 PM
  #35
maxtruck00's Avatar
maxtruck00
New fuel, lots of cranking, and it started!
not running great..
code p0284, cylinder 8 circuit contribution.
p0220, throttle position sensor.
Old Jun 2, 2013 | 08:04 AM
  #36
Tugly's Avatar
Tugly
Ignore that 0284 for now, the gray CPS on the front of the motor can cause this code, so it frequently means nothing. Your fuel was dead, and it will take a number of miles to push the dead fuel and air out of the system. Hopefully, you don't have any clogged injectors... but who knows how it was running before the previous owner shut it down for the last time. It could have been running rough already (from using crap fuel) and the no-start was the coffin nail. I propose you picked up your Powerstroke for a pittance, so this leaves you some budgetary berth for better boomers (injectors).
That TPS gives me pause, but it might prove fruitful to clear all codes and start fresh.
Old Jun 2, 2013 | 11:45 AM
  #37
dn29626's Avatar
dn29626
Anytime i see 2001, i want to get involved. I am late on yours though.
Glad it is running. Because it is running and some of my thoughts have already been suggested by others, i see no need to repeat them.
Preventative maintainence, plan to do the Hutch mod soon and go ahead and disconnect the fuel bowl heater (inside the bowl is neater).
Old Jun 3, 2013 | 07:56 PM
  #38
carltonwebb
Get some diesel kleen cetane booster and run it through there as well just to help clean/lubricate things.
Old Jun 9, 2013 | 02:33 PM
  #39
maxtruck00's Avatar
maxtruck00
I put some fresh fuel and diesel Klean in it today, I'll run it around and hope that fixes that injector, maybe an oil change too.
Old Jun 9, 2013 | 08:43 PM
  #40
carltonwebb
If you are referring to the #8 contribution fault code, its not uncommon to get that code for # 3 & #8 depending on the cps color installed. How is it running? If its running smooth, I would not worry about it. If it has a miss, I would look at the UVCH connections if you have not already. I cannot remember if you did when trying to get it running and have not read back through to look.
Old Jun 9, 2013 | 11:20 PM
  #41
dealwithit's Avatar
dealwithit
That's good you got it running! Has time and miles helped it at all?
tampa psd
35
Sep 11, 2019 09:07 AM
Darkwonderbread
54
Jul 6, 2018 11:22 PM
nossliw
72
Apr 4, 2016 09:22 AM
carbonfootprint
21
Oct 21, 2013 06:06 PM
tdpower
18
Feb 22, 2009 10:00 AM
