2001 no start
Old May 12, 2013 | 05:06 PM
carltonwebb's Avatar
carltonwebb
Check all your relays for good connection under the hood. Specifically, the idm relay. I assume u checked all the fuses. Maybe swap them around. Have u checked to see if GPR is working/has voltage? i guess it gets wts light since its building fuel psi.
Old May 12, 2013 | 05:33 PM
cjgray1974's Avatar
cjgray1974
Are you getting plenty of smoke while cranking? If not its a fuel issue (or hpop).
Old May 12, 2013 | 05:48 PM
maxtruck00's Avatar
maxtruck00
White smoke out of CCV but nothing from exhaust pipe.
Old May 12, 2013 | 05:56 PM
cjgray1974's Avatar
cjgray1974
Then you're not getting fuel into the cylinder. Do you have a way to do an injector buz test? Like AE or the like? Could do a continuiry test using the 42 pin connector.
On my phone now, maybe someone can post a link on the procedure.
Old May 12, 2013 | 06:02 PM
maxtruck00's Avatar
maxtruck00
The scan tool I have is an innova 1303.
I'll google the 42 pin test
Old May 12, 2013 | 06:19 PM
cjgray1974's Avatar
cjgray1974
Look for the thread "big time cold start issues" started by Hkusp. It tells in there how to do it plus a lot of other useful info.
Also tugly's thread "AE class in session"
Old May 12, 2013 | 06:21 PM
maxtruck00's Avatar
maxtruck00
I've heard of a scan tool that is software for laptops and an obd2 patch cord. Anyone heard of this. I have 3 7.3l trucks. Maybe the correct scan tool isn't a bad idea.
Old May 12, 2013 | 06:25 PM
F350-6's Avatar
F350-6
Originally Posted by maxtruck00
Just for fun I pulled a plug out of the oil rail on the drivers side and had a friend crank the engine over while I watched the hole. It sort of puked oil, not exactly hundreds of psi like the book says, is that normal?
You won't see hundreds of psi or oil from the hole with a plug removed, but you should see, holy poop that's a lot of oil. Stop cranking. Stop cranking.
If you're just seeing a little oil dribble or spit out, then you need to check your HPOP for any stickers indicating it's a reman. We've seen issues here where a reman HPOP was bad. It would build pressure if the heads were isolated and a gauge was put on them, but the volume wasn't sufficient to run the injectors.
Old May 12, 2013 | 06:29 PM
cjgray1974's Avatar
cjgray1974
For a proper scan tool check out DP's Infinity and the AE ford enhanced that Riffraff sells
Old May 13, 2013 | 02:53 PM
maxtruck00's Avatar
maxtruck00
I think I will order the diagnostic program from RiffRaff. I'll keep you guys posted with what i find once i receive it.
Old Jun 1, 2013 | 07:23 PM
maxtruck00's Avatar
maxtruck00
i plugged the truck into the AE ford enhanced program today. It passed the buzz test, and only has one code:
P1280 Injector Control Pressure Sensor Circuit Low
Is that referring to the Oil pressure from the HPOP? what would cause this code?
Old Jun 1, 2013 | 07:45 PM
carltonwebb
That code is caused by lack of oil psi to injector rail. I think it has to be greater than 500 psi to crank. If hpop reservoir is full, then could be bad sensor or bad hpop or ipr. If the tin nut is tight on ipr and it will not crank with icp unplugged, i would check voltage to ipr . Then i would plumb in manual gauge to check.
Does it have good battery voltage and spin over strong? It must maintain at least 10.5 volts to crank.
Old Jun 1, 2013 | 07:50 PM
  #28
carltonwebb
I forgot you have AE now. Report back the icp/ipr values while trying to crank.
Old Jun 1, 2013 | 08:11 PM
  #29
maxtruck00's Avatar
maxtruck00
according to AE the rail pressure is 2000-2300. What voltage do i want to see at the sensor?
Fuel desired was at 66?
Im not seeing smoke out the tail pipe, just white smoke out of the CCV..
I'm starting to think it has bad diesel in it..??
Old Jun 1, 2013 | 08:16 PM
  #30
carltonwebb
If u think it has bad fuel, did u ever drain any in a clear container and let it sit? The one I had settled three different levels with mostly water on the bottom and a little diesel in the middle, and some brown crap on the top
