rust hole fix
Old May 4, 2013 | 10:55 AM
riverguideguy's Avatar
riverguideguy
rust hole fix
whats the best way to fix a tiny hole in the floorboard? its only bout the size of a dime and i dont have a welder. if i cleaned it up real good could i just cut a small patch and glue it down with that metal adhesive stuff like some body shops use?
Old May 4, 2013 | 11:06 AM
bucks77ford's Avatar
bucks77ford
Grind down the metal to bare metal and see exactly how thin the surrounding metal is. Most cases, the metal is really thin around a rust hole and you'll need to cut more out. What I'd do is cut out all the rust you need to so it doesn't spread. Cut out a patch about 1/2 to 3/4 inch or so beyond the cut out and paint all the metal and then use either rivets or self tapping sheet metal screws and put your patch down. If you use screws, you can always grind them down a bit underneath to clean them up a bit. Get some seam sealer from your local parts store and coat the seams underneath and inside. That will keep moisture out and keep it from rusting. People do this all the time and patches hold up pretty well. Overlapping seams are killer for rust because they trap moisture, but if you seal them up than the patch will hold for a long time.
69F-250
Jul 2, 2010 07:12 PM
dcunningham
Paint & Bodywork
Jan 16, 2007 09:47 PM
firebolt
Paint & Bodywork
Jan 2, 2004 04:51 AM
djhuebner
Paint & Bodywork
Jun 12, 2003 07:00 PM
DrBlackgaard
Paint & Bodywork
Apr 25, 2003 04:46 PM
