rust hole help
Old Jan 14, 2007 | 10:34 PM
dcunningham's Avatar
dcunningham
Red face rust hole help
I have a rust hole in my driver side door and a rust hole in my roof. what do yall think about using fiberglass to repair it . and how long do yall think it will last.
Old Jan 15, 2007 | 02:01 AM
boilrman's Avatar
boilrman
It would be best to cut out the rust and weld in new metal.
Old Jan 15, 2007 | 08:53 PM
dcunningham
can't weld and don't trust glue
Old Jan 16, 2007 | 07:48 AM
cujo8's Avatar
cujo8
A good friend of mine who's an industrial welder by trade, told me he used some of 3M's Panel Adhesive on one of his automotive projects and said it was as strong as any any weld he had ever done and was quite impressed with the product. He even tested it's bonding strength by gluing together a couple pieces of metal. Once thoroughly dry he tried to separate to two pieces and could not, he did mess the metal up pretty good trying though. You still need to remove the rusted area and prep the surface to clean metal before using a panel adheasive. You do however need to have something to glue to, so you either need to flange the surrounding metal or glue in a couple of pieces of metal to the inside surface of the hole to glue your patch to.
Old Jan 16, 2007 | 04:47 PM
boilrman's Avatar
boilrman
Then I guess you either take it to a body shop for repair or get a rust free door.
Old Jan 16, 2007 | 09:47 PM
dcunningham
thanks for the help
