Recommend Your Best Performance Upgrade/Mod
Old May 11, 2013 | 12:23 AM
  #46
ScaldedDog's Avatar
ScaldedDog
Originally Posted by sunuvabug
I went through all of your great suggestions (thank you all for posting up) and developed a list, in priority order, of potential modifications. I am taking care of the regular maintenance items i.e. oil change, filters etc. as I go. From the top:
  1. Gauges a) EGT/pyrometer - how many are required? b) Transmission Temp c) Fuel Pressure d) Boost - to what PSI should it read as I see everything from 0-20 to 0-60 which I assume is for heavily modded mills?
  2. Chip/tuner - I like the idea of the AutoE unit as a diagnostic tool and I want to know what's what. Also, I only want to get the best out of the stock motor (up to 300 hp as I understand things) without triggering lots of other mods to accomodate huge amounts of hp/torque as I don't need either (I don't think).
  3. Open Element Air Intake System - appears the AIS is highly regarded in these circles
  4. Replace Sensors - ICP, IPR, EBP ... any others? My plan is to get a reading off of the currently installed ones first, then clean/replace as I go when needed.
  5. Hutch/Harpoon mod with Fuel Rail Crossover (RiffRaff)
  6. Bypass Oil Filter
  7. Transmission Cooler - Appears the BTS 6.0 unit comes highly recommended
  8. ELC Coolant replacing the OEM green fluid
  9. Future - upgrade to a 4" exhaust as required (not looking for more noise ... just flow). FYI - our bi-annual provincial emissions test for this truck consists of the technician watching the exhaust tailpipe for 5 straight minutes to ensure there is no instance of 5 continuous seconds of smoke during the 5 minute period.
Does it look like I have things right? Anything I've miss or got wrong?
~ Bugjr ~
1a - 1 is fine. 1b - I'd do 0-40
4 - If the ICP sensor isn't wet with oil, I wouldn't replace it. I would carry a spare CPS, for sure, but don't think proactively replacing sensors is worth the cost.
My $.02, offered for free, and worth every penny.
Mark
Old May 11, 2013 | 08:39 AM
  #47
HKusp's Avatar
HKusp
AE is not a chip/tuner, it is a diagnostic tool, there are no performance gains directly from it. You need to decide on a chip. The 2 most prominent here are DPTuner and PHP with their Hydra set up.
Old May 11, 2013 | 10:23 AM
  #48
Tugly's Avatar
Tugly
Originally Posted by flavo
I post this as sort of a question. I'm surprised not to see the dp infinity mentioned at all. It's less then a set of gauges and AE combined and from what I've read on here performs better and more tests then the AE. I'm a little annoyed that right when I save the $ up to purchase the infinity the price got jacked up 30 percent. Are you all giving me a reason not to buy it, or has it just been overlooked?
Infinity is so new that speaking for myself, I sometimes over look it (old-think)... but this is changing in my mind. I think it's growing so powerful, that it will have a strong presence in the future upgrade market. It takes the place of a tuner, but even without that function, it is a viable gauge/scan tool alternative. I am on the fence right now because I already have so much invested into what I've already done... but that's not to say I wouldn't liquidate gauges and AE in the future to get the Infinity to serve those purposes, plus use it as a TS switcher. I wish its power was incorporated into my double-din head unit to avoid adding yet more custom-dash installation.
That being said, I'm still planning to get a Hydra because of my needs with a moderately-modified Stinky. I don't yet know how the Infinity could tie in with this, other than just gauges/scan tool... but that's still very valuable.
Old May 11, 2013 | 11:01 AM
  #49
HKusp's Avatar
HKusp
To tell you the truth, I am intrigued but a little intimidated by the Infinity at this point. It is very powerful tool and tuner, no doubt and between the AE with full domestic bundle and my DP F5 with 9 tunes, I am over the initial purchase price of the Infinity by a bunch. There are advantages to AE, because you can use it on other vehicles but the data sampling rate is very slow compared to Infinity.
Old May 13, 2013 | 12:01 PM
  #50
sunuvabug's Avatar
sunuvabug
Originally Posted by r-kid
I would do the list like this after all maintenance
1- hutch
2- intake AIS ,just bought one switching from 6637
3- exhaust
4- gauges
5- tuner
The sensors and elc are maintenance, the 6.0 cooler if your towing
Thanks for your input r-kid. My thinking on having the gauges put in early on is, as Tugly alluded to in one of his responses, to get a "baseline reading" on what is going on right now before any mods are made. I was thinking that way I'll have a better sense of the "before and after" of any mods I make. ~ Bugjr ~
Old May 13, 2013 | 12:07 PM
  #51
sunuvabug's Avatar
sunuvabug
Mark
Good advice. i didn't mean to say I'd automatically swap out sensors ... only where needed after cleaning & inspecting them etc.
Also, thanks for the suggestion on boost range ... this helps. ~ bugjr ~
Old May 13, 2013 | 12:50 PM
  #52
Tim Hodgson's Avatar
Tim Hodgson
HKusp: I am not over the initial price because I haven't bought AE yet, so I am very intrigued by Infinity also and would like to know what you and others think about buying Infinity for its scanning ability irrespective of its tuning function.
[OT: Last month my wife and I watched The Seekers (clearly Wayne's best performance); Stagecoach (our second favorite); and the Man Who Shot Liberty Valence. All highly recommended for a good dose of Americana.]
Old May 13, 2013 | 02:32 PM
  #53
timmyboy76's Avatar
timmyboy76
Name ur price, Tug.
OP, my mod is switch'n to WVO...2nd is Hutch mod.
Dieseltorque
Mar 27, 2013 02:00 PM
Jim Hunt
15
May 19, 2010 06:23 PM
DemonRace6
21
Sep 20, 2007 11:17 AM
99powerstrokeSD
26
Aug 11, 2006 05:17 AM
Pablo69
Oct 17, 2004 08:29 PM
