FICM problems
Old Apr 30, 2013 | 10:07 PM
  #61
npccpartsman's Avatar
npccpartsman
U0306 usually means the FICM has been flashed separately from the PCM ("aftermarket flash") but it doesn't usually cause a problem. It could also mean that it was a FICM from a completely different vehicle. U0105 means that it lost communication with the PCM which might mean that you didn't get it plugged back in properly or turned the key on with it not in the vehicle (maybe).
FWIW--I wouldn't worry about any further diagnostics until I got the FICM repaired (probably your no start anyway). It will give your batteries a chance to get a nice fat 10A charge while it's gone. BTW--it's also a great time to get your batteries load tested separately to see their health. Just make sure they're fully charged first.
Something about chopped liver comes to mind here.
Old Apr 30, 2013 | 11:12 PM
  #62
jajones1988's Avatar
jajones1988
ya im going to sent the FICM sent out tomorrow. Should I take the batteries to an auto parts store to have them check it or is that something i can do myself?
Old May 1, 2013 | 05:32 AM
  #63
npccpartsman
You need a load tester to check the batteries. Auto parts stores will do that for free
Old May 1, 2013 | 07:19 AM
  #64
bismic's Avatar
bismic
You might look up TSB 10-12-6:
TSB 10-12-6
6.0L - RUNS ROUGH, LACKS POWER, HARD START, NO START
Also, I believe that there is a minimum battery voltage for starting - 9.5V IIRC.
Old May 1, 2013 | 11:52 AM
  #65
jajones1988
Does anyone know if FICMREPAIR.COM will charge more because I fried a component off I tried get ahold of them with no answer back?
Old May 1, 2013 | 11:57 AM
  #66
firedaniel's Avatar
firedaniel
http://www.ford-trucks.com/.../12166...al-parts.html? ...
I got one from international. Works perfectly for $180!
Old May 1, 2013 | 12:01 PM
  #67
firedaniel's Avatar
firedaniel
Not sure why that didn't work. This should fix it.
https://www.ford-trucks.com/forums/showthread.php?t=1216682
Old May 1, 2013 | 12:19 PM
  #68
jajones1988
so they sell you the whole board and you just unscrew the old board and put the new one back in a put it back in the truck? What about programming?
Old May 1, 2013 | 12:25 PM
  #69
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
They basically fix yours or send one similar to you back to you programmed and ready to run.
Old May 1, 2013 | 12:33 PM
  #70
jajones1988
is that FICMrepair.com or the international thing?
Old May 1, 2013 | 02:03 PM
  #71
firedaniel's Avatar
firedaniel
Both of those options are the power board. The logic board stores the programming. You will reuse it with the new board.
Old May 1, 2013 | 02:13 PM
  #72
Rusty Axlerod's Avatar
Rusty Axlerod
Don't feel bad, I think it happens to all of us once in a while. Besides, you did see the title of the thread and we knew something was rattling around in there Sometimes we just gotta take the long way around .
Also as you implied above, getting the power side of the FICM working is necessary but it may not be the whole problem.
Old May 1, 2013 | 02:25 PM
  #73
jajones1988
I hope that is all that is wrong or im never going to hear the end of it from my wife. Im still trying to get an estimate for ficmrepair.com before i sent it out.
Old May 1, 2013 | 03:53 PM
  #74
npccpartsman
I don't feel bad at all Rusty--LOL. Following the threads gives me something to do on the slow work days.
Old May 1, 2013 | 03:59 PM
  #75
npccpartsman
Depending on what level of repair (they're all good) and flash you choose probably between $300 and $500 and better than anything you can get from Ford or Navistar.
