FICM problems
Old Apr 29, 2013 | 07:45 PM
  #31
Rusty Axlerod's Avatar
Rusty Axlerod
Intake manifold gaskets are re-useable unless they are damaged.
Old Apr 29, 2013 | 07:46 PM
  #32
jajones1988's Avatar
jajones1988
well i am at 3600 ft altitude and my reader said while cranking the intake manifold pressure was 12.5 PSI and I am wondering if that is good or bad Ill look into get a reading off of the exhaust back pressure sensor and let you know what that is.
Old Apr 29, 2013 | 07:53 PM
  #33
Rusty Axlerod
Correction, I do have voltage numbers for MAP
MAP_V 1.30 key on- 1.33 cranking- 1.40 at high idle (2,500 rpm) 0.5 - 4.5 operating range. VOLT Manifold Absolute Pressure
Map sensor is on the firewall and connects to the intake manifold by a hose on passenger side rail of intake manifold.
LG/BK wire is signal
Old Apr 29, 2013 | 08:06 PM
  #34
Rusty Axlerod
Had to google that one but that looks about right, somewhere around 12 Pisa depending on the weather.
Old Apr 29, 2013 | 08:07 PM
  #35
jajones1988
im at 3600 ft and i am getting 12.5 PSI intake manifold pressure dont know if that good or bad. Also was wondering if there is a emergency fuel shut off valve on the 03's if so where is it at.
Old Apr 29, 2013 | 08:13 PM
  #36
Rusty Axlerod
Emergency fuel shut off is behind passengers side kick panel. It has a button on top to reset.
Old Apr 29, 2013 | 09:31 PM
  #37
jajones1988
well i might have found a problem the atmospheric pressure at my elevation is 12.87 PSI and while i crank the engine it does not change. To me the pressure should go up right? is there a way to test and see if my intake manifold gasket are shot? I was reading something about hooking up a vacuum pump to something and put a vacuum on it and see if it keep the vacuum?
Old Apr 29, 2013 | 09:36 PM
  #38
jajones1988
I took off the engine fuel filter and turned the key and it filled up fast so im pretty sure its not fuel.
Old Apr 29, 2013 | 09:37 PM
  #39
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Baro, map and EBP should match KOEO
Baro only changes with altitude and barometric pressure.
Map should be close to Baro at idle and crank
Josh
Old Apr 29, 2013 | 09:44 PM
  #40
jajones1988
it didn't sound to good when i separated the manifold and the block and it was a little hard to push the intake bolts back thru to tighten them back down.
Old Apr 29, 2013 | 09:47 PM
  #41
jajones1988
Josh
O so is there anyway to check to see if the intake gasket are still intact. On the torque app it says there is a intake manifold pressure sensor, stupid or kinda late question is that the MAP sensor?
Old Apr 29, 2013 | 11:46 PM
  #42
jajones1988
I was thinking about trying to test to see if the ipr is still actually connected, because i never disconnected it but it was hit by alot of stuff while i was working on the engine. but if i am getting 2v out of the icp sensor than it has to be connected becasue the valve is closed to build up pressure right?
Old Apr 30, 2013 | 04:55 AM
  #43
Rusty Axlerod
MAP is Manifold pressure.
BARO is barometric pressure
EBP is exhaust pressure
Engine makes virtually 0 boost when cranking with starter and very little (almost 0) at idle. Fuel is injected directly into cylinder so if air is not blocked somehow it should try to start even if intake gaskets are leaking.
Old Apr 30, 2013 | 10:45 AM
  #44
jajones1988
ok so another thing i was worried about what that the icp sensor failed and as i replaced it there was oil on the on the plug so i cleaned it and sense i am getting a reading off of the wire than the plug would still be good right?
Old Apr 30, 2013 | 11:01 AM
  #45
jajones1988
so i am guessing this is the fuse/relay box the the engine computers i am getting 11.8 volt to both of the fuses but does anyone know how to test the relays?
