boost fooler ?
Old Apr 19, 2013 | 12:00 PM
mikec91's Avatar
mikec91
Yes no leaks on the up pipes
Old Apr 19, 2013 | 12:26 PM
rideracelivemx7's Avatar
rideracelivemx7
keep in mind, if you have an intercooler you loose ~2-3 of PSI. it does sound a smidge low as you should hit about 20 but its also in the codition of your injectors flowing the correct amount of fuel and the condition of the compressor wheel. both of them can and will effect the amount of boost. Boost does not meassure power nessesarily, if the truck is running great and pulls just as good while NOT running hot then id just say your trucks doing alright and leave it alone.
Another note is your altitude effects loss aswell.
Rod Jr.
Jan 28, 2019 11:16 AM
ved0303
Apr 30, 2015 09:27 PM
bleeds blue
Apr 29, 2014 06:56 PM
jdamato1
Feb 19, 2010 10:17 AM
clux
May 29, 2006 05:00 PM
