Hard starting help
Old May 29, 2013 | 07:54 AM
  #31
rufushusky's Avatar
rufushusky
Update: a few weeks ago I took the truck to minuteman truck (sponsor) in Walpole, MA.
Turned out it was a two part issue... a "jumper" line from the HPOP to the oil rails was loose under the valve cover causing the HPOP res to drain and the injector O-rings where worn out. Both were repaired within 24 hours. Truck runs better now than the day I picked it up.
Old May 29, 2013 | 08:22 AM
  #32
Tugly's Avatar
Tugly
Thank you for getting back to us on that. This thread is a good example of walking through an oil problem, complete with, symptoms, data, troubleshooting, and a resolution. Great job!
7.3 forever
Aug 27, 2015 03:20 PM
powerstroke84
13
Feb 1, 2015 10:05 AM
guthrie&co
Jan 16, 2014 01:26 PM
JamesHajek
74
Jan 29, 2012 06:43 PM
bryanlindborg600
Oct 22, 2009 08:58 AM
