One day I put my 89 BII in 4 low pulling fence, and the rear anti-lock light and e-brake light came on. The next day when I started her up, no lights. They always cone on together, but are not always on. What gives?
somthing may have snaged a wire while you where pulling the fence for the abs as for the e brake light mine did a sorta random thing it worked somtimes and somtimes didnt turns out the switch for the ebrake light just above the ebrake pedal was loose you should check that on yours
My anti lock light came on intermitently and then stayed on all the time it could be a variety of things,sensor on the rear pumpkin ,rabs valve,brake fluid.I ended up doing a brake job and it went away.
