rear antilock light
Old May 16, 2007 | 04:05 PM
cuztom79's Avatar
cuztom79
rear antilock light
i just changed my brake booster,put it back together, bled the entire system and now the rear antilock light came on. any ideas on why?
Old May 17, 2007 | 11:28 PM
ReAX's Avatar
ReAX
You maynot have bled the ABS valve completely, or the sensor on the pumkin is damaged. I was much happier with out rear ABS on my 89, try it out. If you find you like it, you can remove the bulb from the cluster.
