Rear antilock light
Old Jul 30, 2018 | 01:24 AM
BS51993's Avatar
BS51993
Rear antilock light
Yesterday, I noticed my "rear antilock" light was on. I am trying to determine if there is an actual problem or if its just a fluke. I drove it on a 42 mile round trip yesterday and it rode the same as always and I didn't notice any issues. No noises, lack of performance, etc. Has anyone else had this issue before? 1991 F-150 302/E4OD. Unsure of gearing.
Old Jul 30, 2018 | 07:58 AM
rla2005's Avatar
rla2005
Some info from Steve83: RABS Codes
Old Jul 31, 2018 | 10:50 PM
BS51993's Avatar
BS51993
The guide shows what it means depending on how many times it flashes. However, the light does not flash. It just stays on and I don't see that on the guide.
Old Aug 1, 2018 | 08:15 AM
rla2005's Avatar
rla2005
Did you read the information after the Code Chart for how to obtain the Flashout Codes?
To obtain the flashout code, locate the RABS diagnostic connector (with the Bk/Or wire); on '92-96, it's above the right end of the glove box bottom corner, inside the dash; on earlier trucks, it's between the brake & e-brake pedals near the firewall. Separate the R wire's connector half, turn the key to RUN, and attach a jumper wire to Bk/Or. Momentarily ground the Bk/OR jumper to the chassis (the lighter socket shell). When the ground is made and then broken, the REAR ABS light should begin to flash.
Old Aug 1, 2018 | 09:25 AM
Lee Jones's Avatar
Lee Jones
I have a 1990 7.3 and it has done that since I got it. The truck runs and pulls the same as without the light so I haven't changed anything.
Old Aug 1, 2018 | 09:59 PM
sp5937's Avatar
sp5937
My 1989 F150 has this light on also. If I clear it it stays off for a few miles but always comes back on I haven't experienced any downside to it being on, brakes still operate fine...
Old Aug 1, 2018 | 10:58 PM
BS51993's Avatar
BS51993
I have solved the problem. Turned out to be low brake fluid. After filling, the light went off. I am a bit confused as to why low brake fluid would trigger an ABS light and cause unnecessary panic for me.
Old Aug 2, 2018 | 07:22 AM
rla2005's Avatar
rla2005
If the red Brake light is triggered on, low brake fluid, parking brake applied, etc. then the yellow Rear ABS light is triggered on. You never stated the red Brake lamp was on. With that on the RABS system is disabled which causes the yellow Rear ABS lamp to illuminate too.
Old Aug 2, 2018 | 11:26 PM
BS51993's Avatar
BS51993
They both were on but now are off after adding brake fluid. I am now monitoring the system for leaks.
Old Aug 3, 2018 | 08:00 PM
ifrythings's Avatar
ifrythings
Only low brake fluid (and low vacuum on a diesel) will cause the red brake light and RABS light to illuminate. The reason why low brake fluid disables the RABS is because the RABS has an accumulator that can store fluid while the system is trying to modulate the rear brake pressure, if you have low fluid and the RABS were to engage it could cause the master cylinder to suck air in and you loose brakes, not something you want to have happen.
By any chance did you notice if the front half or rear half of the master cylinder reservoir was lower than the other? This would indicate which circuit is leaking fluid, rear circuit is the front of the master ( closest to the cab) and the front is the other circuit.
Old Aug 5, 2018 | 09:15 PM
BS51993's Avatar
BS51993
I did not notice one lower than the other. They both appeared even. I have only driven 5 miles since refilling as I take a 4 banger to work due to distance so I haven't used the brakes enough to notice any changes.
vzfiostech2
Jan 2, 2016 06:53 PM
Bax2008
Aerostar
Jun 12, 2009 07:29 PM
cyncycles
1983 - 2012 Ranger & B-Series
Mar 14, 2004 08:09 PM
Rudzvetz
Dec 16, 2003 10:40 AM
mwalsh
Aerostar
Jul 27, 2001 04:08 PM
