351w heads - worth anything?
Well that's a good lot of photos. The date code indicates the casting was made on June 22nd, 1973.
What makes the C9OE and D0OE heads better is large valves and ports and small combustion chambers. Way back when, they were the "good" heads to get.
If you are lucky, you might get away with a light hand sanding of the gasket surfaces and hand lapping of the valves. By taking out the exhaust valves, you will see if there are hardened seats installed.
tazcliff
26
04-05-2011 10:31 AM
