95 explorer 4.0 & 4r55e swap into a 98 ranger
I swapped a 95 4.0 and 4r55e into a 98 ranger 4.0 & 4r44e. I ended up pulling top off of the ranger to put on the explore motor so I could use my harness. I also used the old harness on the transmission. On the 4r55e there is no output speed sensor but on the 4r44e there was. I am getting a output speed control error from the local oriellys. Is there a way to put a sensor on this as it just has a solid boss now? It has a problem shifting down and it stays in to high a gear and around 1000-2000 rpm shutters like a manual starting out in wrong gear. any help would be awesome thanks
Your '98 4.0L should have also had a 4R55e. It was the only trans offered with the 4.0L. The 2.3L and the 3.0L got the 4R44e. The difference is torque rating.
This is part of why I never do and never recommend trans swaps, especially not from different years. Rebuilding is the only way to go unless something makes a rebuild impractical.
The way to do it is to take your old trans, rebuild it, and put it back on. You can use some part out of the other trans, a lot of the internal parts should be replaced with new/updated parts.
jimmy dale
1983 - 2012 Ranger & B-Series
01-28-2018 10:19 AM
