CEL - am I reading it right?
Old Apr 6, 2013 | 06:41 PM
blueray's Avatar
blueray
So - transmission issues have been irritating me. Slipping, thumping, etc. Planning to take to a shop on Monday but first I ran the diag at Fuel Injection Technical Library » How To Run a Self-Test
From what I'm seeing, my codes are
111 - System Pass
116 - ECT out of self test range
767 - ??? I can't find t his anywhere ...
I took a video about the fourth time I did it. Posted on youtube.
1992 Ford F250 CEL - YouTube
What does ECT out of self test range mean? Am I reading the codes wrong?
Thanks!
Old Apr 6, 2013 | 06:45 PM
blueray's Avatar
blueray
Quick google of ECT is probably cold engine. I hadn't ran it at all to get it warm. Didn't realize that I needed to.
So, if I'm reading correctly, that may be the first one. Engine runs fine but transmission is slipping, clunking when I shift from park and hunting when I'm driving.
Old Apr 6, 2013 | 06:55 PM
White 97 xlt's Avatar
White 97 xlt
111 - System Pass
Thanks!
I think your truck will have 2 digit codes, also all code are always repeated, so you have 11, 11, 67, 67.. The 11 is all clear for the KOEO portion of the test. The 67 is probably from CM part of the test..
Here is a thread on the 67 code. https://www.ford-trucks.com/forums/9...code-67-a.html
Old Apr 6, 2013 | 07:19 PM
blueray's Avatar
blueray
Thanks - I was assuming it was three for some reason. Would the Neutral safety circuit failure cause transmission to go funky? I can certainly go get a new one and replace it ...
Old Apr 6, 2013 | 07:23 PM
White 97 xlt
If you have an E4OD any code can cause the transmission to go into limp mode..
Old Apr 6, 2013 | 07:31 PM
blueray's Avatar
blueray
What does limp mode do? Would it cause the symptoms I'm having? Appreciate the insight. Gives me an idea where to go.
Old Apr 6, 2013 | 07:40 PM
White 97 xlt
Limp mode is what Ford gave you to get home or to a shop when something goes wrong... It's protecting it's self.....
The E4OD goes to full line pressure and it slams as it shifts gears, it is designed to go full pressure to keep it from slipping and burning itself up.
A little searching for limp mode and E4OD will get you a lot of info..
snurchi
Sep 7, 2010 09:05 PM
F16Driver
Sep 11, 2007 10:04 AM
Tim Dawson
Bronco II
Apr 28, 2007 07:57 PM
dongreene
Feb 20, 2006 07:54 AM
crazandy
Nov 26, 2004 06:55 PM
