KOER codes need help
Old Sep 11, 2007 | 07:43 AM
F16Driver's Avatar
F16Driver
<TABLE><TBODY><TR><TD vAlign=top width="100%">91 explorer eb
KOEO codes are clear, I actually cleared them last week while trying to diagnose this overdrive problem.
KOER codes 21 77 74
I need a little help with these codes. All the code sheets i have say there should be 3 digit codes not 2 digit codes. Whats up with that??
</TD></TR></TBODY></TABLE>
Old Sep 11, 2007 | 08:42 AM
quicklook2's Avatar
quicklook2
21 cooling temp sensor out of range
77 operator error/wot not sensed
74 brake on/off switch fault/ not accuated
Old Sep 11, 2007 | 10:04 AM
mrshorty's Avatar
mrshorty
Your '91 is the only year 4.0 that outputs 2 digit codes. I don't know whose code sheets you're using, but there are a lot of code lists out there (especially on the internet) that don't know which applications output which type of code.
KOER 21 is usually from performing the KOER test on a cold engine. The computer expects the ECT output to be above a certain point (probably something like 180 F) during the KOER test. If it's cold, you can get a KOER 21
KOER 77 and 74 are almost always operator error. I don't know whose instructions you are using, but it seems there are a lot of KOER instructions out there that don't fully explain the test protocol. Just after engine id is output, you need to press on the brake to actuate the BOO switch, which almost always resolves the 74. Later in the test, when the "goose pulse" is given, you need to "goose" the throttle to resolve the 77.
Check those items and repeat the KOER test.
Visseroth
May 13, 2010 04:11 AM
Rickx
15
Jul 19, 2009 11:28 AM
cpomike
Dec 23, 2004 09:12 AM
Deadman2891
Jul 17, 2004 10:39 AM
