new Stancor 902 GPR...same problem
Old Apr 4, 2013 | 08:32 PM
Cell's's Avatar
Cell's
Question new Stancor 902 GPR...same problem
During the winter I started having hard starts and romps when first starting my truck . I did a continuity test on the 9 pin connectors on the valve covers . Found one on the passenger side (cyl#5) with no continuity .
I also have a cheapo battery tester that plugs into the cigarette lighter which tells me when the GP's are done energizing before I start the truck . Occasionally , the GP's would not energize when I turned the key on so I would jump the GPR to get it fired up . So I bought a Stancor 586-902 from Mouser Electronics to replace the intermittent GPR . I thought I was going to have to replace a GP also so I bought 4 new ones from the stealership to replace them all when I was under the valve covers .
This past weekend , I took the passenger side valve cover off to find the connector partially unplugged . I pushed it back on then did a continuity test again and had that problem fixed , so I didn't replace any of the GP's . I also did the 25cent mod on that side . Then I torqued the injector hold downs and rocker retaining bolts . All the injector hold downs were loose . I then went to the drivers side and did the same procedure with the 25cent mod too . I put it all together and the truck sounds quieter to me now .
BUT.... the intermitent GPR energizing problem is still happening .
I'm stumped as to what to check in the way of wiring .
Do you guys think I might have a bad ground problem happening ??
Sometimes when the GPR doesn't energize and I hit the starter , The GPR will then energize .
Thank-you for your thoughts !
Old Apr 5, 2013 | 07:21 AM
Tugly's Avatar
Tugly
It sounds like you need a GPR LED. The control for the GPR is direct from the PCM, so you might have a bad Air Intak Temperature sensor, a bad ground somewhere, a loose terminal, a bad connection from the PCM plug, or something similar.
Romps are most typical on old injectors with dead dinos. 5-40 oil really helps to prevent romps in cold weather.
Old Apr 5, 2013 | 07:25 PM
Cell's's Avatar
Cell's
Thank-you Tugly for the wiring schematics . I have that one saved in my Ford folder for reference .
Crap , I hate wiring problems . Lots of places for problems to arise from .
I guess I will start by making sure I have good grounds and then go from there .
The hardest part of this will be because it is an intermittent problem . And mostly it happens when I got to go to work which makes it hard to do something to it because I have to be somewhere .
bowranger
Dec 29, 2014 03:18 PM
fff_ca2000
Apr 8, 2008 06:47 PM
Dually77
Jan 13, 2008 07:31 PM
FFemt5287
Jan 10, 2007 04:27 PM
MDB
Jan 4, 2005 06:06 PM
