Bellowed up pipes?
Old Apr 4, 2013 | 05:49 PM
cjgray1974's Avatar
cjgray1974
Bellowed up pipes?
So I was cleaning my engine valley today and realized my ebpv was leaking, so i pulled it off and seen I had an exhaust leak where the up pipes come into the collector. Broke three bolts getting that off and ended up taking off one up pipe.
I'm considering just getting the bellowed up pipes from Riffraff. does any one know if they come with a new collector and hardware?
The only reason I'm hesitating is because I'm planning on stage 2 sticks and a turbo upgrade next winter and DP suggests the HSFB for stage 2's. The bellowed up pipes can't be used with the HSFB because the HSFB sets straight to the motor and the garrett sits at an angle.
So who all runs the garrett 38 with stage 2's and are you happy with it. i may get the up pipes now and go with the garrett 38 next year. Just dont want to spend the money then take them off in a year
Old Apr 4, 2013 | 06:08 PM
Shake-N-Bake's Avatar
Shake-N-Bake
When I bought the up pipes from Riffraff, they came with the collector, two metal gaskets and new hardware for the upper and lower connection points.
Old Apr 4, 2013 | 10:27 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I'm gonna say it....
The Dorman bellowed uppies are less than half the price ($190), and several of us have installed them recently. I haven't heard of anyone that is not happy with them so far. You might have to grind a bolt or two, but for $250 in savings I was happy to. If you think you might be switching turbos in a year, you may want to go that route. When you switch, you should have no problem selling them to recover some of the money you spent on them. Same with the IH bellowed pipes, but you will be looking to recover a LOT more money.
Old Apr 4, 2013 | 11:45 PM
KH85's Avatar
KH85
I've got the IH bellowed ups and Im very happy with them so far. Came with everything I needed including the collector.
No idea on the 38r though I haven't gone there just yet.
Old Apr 5, 2013 | 12:31 AM
Bonanza35's Avatar
Bonanza35
38R will be just fine with stage 2 injectors. Its your choice.
Old Apr 5, 2013 | 01:17 AM
Texas Chain Ring's Avatar
Texas Chain Ring
Why would the up pipes need to be replaced when installing a 38r turbo? And what is the collector?
Old Apr 5, 2013 | 01:42 AM
BigAlsPSD's Avatar
BigAlsPSD
The "Collector" aka "Baby's butt" is where the 2 up pipes coming up from the manifold collect to join and drive the turbine housing of the turbo. 2 into 1 collector.
If your up pipes were in good condition when installing a 38R there would be no "need" to install them.
Old Apr 5, 2013 | 07:57 AM
Ford79's Avatar
Ford79
I'm going to second this.
I installed a set on a customer vehicle about 2 weeks ago, fit was great aside from having to cut the collector bolts down by 1/4". To me, this is not a problem at all, just a minor annoyance. There are no leaks and they work just as good as the International pipes, IMO.
If the Dorman pipes were around 3 years ago I would have those instead of the International ones...........
Old Apr 5, 2013 | 08:42 AM
Texas Chain Ring
cheap is not good and good is not cheap. did anyone buy their trucks because they were cheap knock offs?
Old Apr 5, 2013 | 09:14 AM
Ford79's Avatar
Ford79
So, one should pay more than double for a product because?????????????
If they work and fit the same what's the difference in the end?
Oh yeah, more $$$ in your pocket for other stuff...
Old Apr 5, 2013 | 09:50 AM
timmyboy76's Avatar
timmyboy76
i'll go as far and say, when my bellows start leaking, i'm slap'n a set of donuts in. The job IS not difficult at all, plus if they last 100k, thats 3yrs of driving for me.
Old Apr 5, 2013 | 09:55 AM
cjgray1974's Avatar
cjgray1974
If I go with the HSFB turbo instead of the garrett 38 you have to ghange the up pipes because of the angle the HSFB sits. The stock up's wont work with it.
Old Apr 5, 2013 | 09:59 AM
timmyboy76's Avatar
timmyboy76
depending on cost, the T4/s366 set-up, comes with uppipes..(bellowed), PLUS the s366 turbo IS rebuildable.
Old Apr 5, 2013 | 10:03 AM
cjgray1974's Avatar
cjgray1974
Thats what I'm thinking i'm gonna do. Then decide what turbo to go with later. Had a friend tell me to consider the T4 style turbos. I'll have to do some research.
Old Apr 5, 2013 | 10:06 AM
cjgray1974's Avatar
cjgray1974
Haha your reading my mind. Who sells these. Need something thats still gonna be good for towing and DD
