Offset,backspace and tire size?
Old Mar 30, 2013 | 12:06 AM
Visualfx's Avatar
Visualfx
I'm about to order some wheels and tires and am confused on exactly what to get. I have an 03 v10 with a bds 6" lift I'm looking to get some. 22" rockstars with some nitto mud grapplers but didn't realize there was so many options. I just have no clue when it comes to offset and back spacing. What is everyone running? What's the preferred/ideal combination? Anybody know of the best/cheapest place to order these from?
Old Mar 31, 2013 | 02:31 AM
Vr4tune's Avatar
Vr4tune
What size tire do you want to run? This plays a big factor in offset. If you don't go any larger than a 37x12.5 tire I would highly suggest a -12 offset if you plans are bigger than that then go -24 offset.
Old Mar 31, 2013 | 10:15 AM
Visualfx's Avatar
Visualfx
I was thinking 35 or 37 but was leaning more towards 35 in order to avoid any rubbing issues. What about back spacing?
Old Mar 31, 2013 | 12:02 PM
Vr4tune's Avatar
Vr4tune
I can't tell you the backspacing without knowing the rim width.
Read my posts in this thread. I have the same screen name.
http://powerstrokenation.com/forums/...d.php?t=135745
Old Mar 31, 2013 | 02:50 PM
jrproper's Avatar
jrproper
You should be looking for 4.5" backspacing...
22"x9" rim w/4.5" backspacing = -12mm offset
22"x10" rim w/4.5 backspacing = -24mm offset
Old Mar 31, 2013 | 03:09 PM
Visualfx's Avatar
Visualfx
Thank you guys for all the help was going nuts trying to figure out what exactly to get
Old Mar 31, 2013 | 03:12 PM
Visualfx's Avatar
Visualfx
Now would a -24mm offset create more lip than a -12mm offset? Just trying to figure out if I have this straight
Old Apr 1, 2013 | 12:13 AM
Visualfx's Avatar
Visualfx
confused on wheel offset and backspacing - PowerStrokeNation : Ford Powerstroke Diesel Forum
Just checked they are 22"x9.5"
Old Apr 1, 2013 | 12:57 AM
jrproper's Avatar
jrproper
You also need to know the backspacing to know the offset... one or the other should be listed for the new wheel.
Play with this for a bit, should help you understand more about offset/backspacing:
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
An illustration to help also:
Old Apr 1, 2013 | 03:24 AM
Vr4tune's Avatar
Vr4tune
The goal is to determine where you want the tire to sit. right?
Those above don't match TIRE LOCATION.
These below match up tire location granted they HAVE THE SAME SIZE TIRE let's say 35x12.5 R22 for the examples below!
22"x9" rim w/4.5" backspacing = -12mm offset (Will stick out of fender 1/2inch)
22"x10" rim w/5" backspacing = -12mm offset (Will stick out of fender 1/2inch)
22"x9" rim w/4 backspacing = -24mm offset (Will stick out of fender 1 inch)
22"x10" rim w/4.5 backspacing = -24mm offset (Will stick out of fender 1 inch)
My point being is to use offset as a primary source of information and not backspace. The required backspace changes to keep the tire in the exact same location but the OFFSET WILL STAY THE SAME.
Remember offset tells you where the center of the rim is, and WHERE THE CENTER OF THE RIM IS WILL ALSO BE THE CENTER OR THE TIRE. This will NOT be true for the backspace as it will move the tires center half of the distance of what the width of the rim width change is.
(Example: if you add an inch in rim width then you also change the backspace by half an inch.)
I hope I explained it clearly enough. It can be hard to explain without showing it. Sorry if this comes across as a little dickish as that's not my intent but is to inform.
anthony f47
18
May 11, 2016 12:12 AM
madcatter33
Mar 31, 2009 08:12 AM
BigNiner19
2004 - 2008 F150
Oct 28, 2008 08:40 AM
Louie3
Offroad & 4x4
20
Aug 4, 2008 07:43 PM
JoeSwing78
Nov 3, 2005 08:07 AM
