Ex tire size help
Old Mar 30, 2009 | 12:14 PM
madcatter33's Avatar
madcatter33
Ex tire size help
I have a set of 285/75/16 tires on the EX now.I like the way they look as far as filling up the wheel wells and not looking too small.I ordered a set of 20x9 wheels for it so what would the equivilant tire size be for them.Also any special preferences on tires?Thanks alot.
Old Mar 30, 2009 | 02:06 PM
BostonX73's Avatar
BostonX73
You can get some 33x12.5 on 20s like the Toyo Open Country Mud Terrain to keep the same diameter, but you will be a bit wider and probably get some rubbing unless you get the right backspacing in the wheels. do you want a mud type tire, or more all terrain?
305/55 20s are just about the same diameter, couple good tire choices, an less rub concerns.
See what the guys running the 20" pull-offs run.
325/50 20s would be the same ballpark for diameter too.
Dick Cepek Radial F-C II
Old Mar 31, 2009 | 06:40 AM
gotahava4d's Avatar
gotahava4d
awesome website for figuring out tire size...
http://www.1010tires.com/TireSizeCalculator.asp
Old Mar 31, 2009 | 08:12 AM
gr8scott72's Avatar
gr8scott72
Tire Size Calculator - tire & wheel plus sizing
I like this one better:
Tire size calculator
