I ordered 4, 33x12.50R15 TSL Radials BUT its shows I ordered 2 36x12.50R15 and 2 33x12.50R15 so should I be mad that I'm getting a bigger size tire for the same price as a smaller one?
I called in earlier and I was marked down to reccive 36's. Man If I had the set up to run them I would be thrilled to have reccived bigger tires for cheap
Well, hows this for a deal. Have them send you the rest of the set of 36's, drive them over to Virginia and I'll trade you out with a set of 33 swampers plus and extra worn out set of 33 swamper SX's for those 36's!
They will probably just charge your credit card for the higher priced tires because you actually received them. I would return them on their dime and pickup slip and order tires from a better place.
Your truck will need a 6 inch lift and trim front fenders and bumper corners. I messed up a brand new set of 36 swamper radials on my old 93 F-150. I trimmed fender with a saw, but not enough and went wheelin and cut the crap out of the fronts . There tall for 36's, alot taller than a 35 bfg.
I purchased white wall as they were cheaper and reccived black wall and was charged nothing more. I do have 5.5" of lift so I'm good with 33's. I was expecting the tires to be alot wider but seem narrow for 12.5 my buddies BFG AT are wider!!!???
