Sam's NO START thread
Old May 20, 2013 | 01:37 AM
  #76
strokin'_tatsch's Avatar
strokin'_tatsch
Originally Posted by sleepyhead416
You need to block off 1-head ck pressure. Then block off other head ck pressure so you can figure out what side is leaking. Have you checked pressure from HPOP with 1 of line blocked? (Hoses not connected to head)?
FYI.... Unless you have an HPX line, the oil rails in the heads are not connected in any way. So all you need to do is put the gauge in each oil rail and check pressure. If you do have an HPX line, all you need to do is remove that and check pressure on each rail.. to check pressure just from the pump, you'll need to connect the HPOP line to the gauge.
If you have 125psi in each oil rail without an HPX line, there's a pretty slim chance injector o-rings are causing the problem. That would mean that one, you'd have to have a leak on each bank that happens to be leaking the same amount on each side. Possible, but I've yet to see that happen.
Old Jun 17, 2013 | 06:59 PM
  #77
95_Dually's Avatar
95_Dually
I have not looked at the truck in almost a month. Too darn busy....LOL
I have all the fittings required to block off 1HPOP line so I can test the HPOP at the other one. I am thinking a bad HPOP at this time, but I will confirm soon.
Old Jun 17, 2013 | 07:07 PM
  #78
427 fordman's Avatar
427 fordman
That "busy" thing happens sometimes Sam.
Old Jun 17, 2013 | 07:10 PM
  #79
95_Dually's Avatar
95_Dually
In this case busy is good. The business is booming again. It has been slow since 2009 so I am really excited.
Old Jun 17, 2013 | 08:19 PM
  #80
oldbird1965's Avatar
oldbird1965
Well then, stay busy, LOL. I hope your right about the hpop, you'll need a T500 anyway. Speaking of Joey's hpop's, has anybody heard about the T1000??
Old Jun 17, 2013 | 08:22 PM
  #81
95_Dually's Avatar
95_Dually
I read about the T1000 but I don't think I will need one. The 500 is more than enough for me...LOL
Old Jun 18, 2013 | 06:01 AM
  #82
427 fordman
Glenn, I haven't bothered Joey for a while so I'm not sure if he's getting any built yet or not. Maybe someone does.
Old Jun 18, 2013 | 03:46 PM
  #83
strokin'_tatsch
Negative ghost rider.
Tim Shultz
22
Aug 15, 2013 09:45 PM
jbear_tx
79
Feb 19, 2013 05:36 AM
78pace
16
Sep 1, 2011 08:00 PM
wyocat24
May 3, 2011 08:49 AM
GeoffNJ
15
Oct 20, 2007 08:53 AM
