Sam's NO START thread
Old May 5, 2013 | 09:11 PM
  #61
sleepyhead416's Avatar
sleepyhead416
Isolate your problem to left or right side then pull valve covers. while cranking over look for oil leak around injectors. You have a high pressure gauge I take it.
Old May 5, 2013 | 09:16 PM
  #62
95_Dually's Avatar
95_Dually
I have a 125PSI on both banks. Yes I have a mechanical HPO gauge.
Old May 18, 2013 | 12:03 AM
  #63
95_Dually's Avatar
95_Dually
I replaced the IPR and that was not the problem. I pulled the valve covers to see if I have a high pressure oil leak in there but it all looks good. I am thinking the HPOP has gone south. What do you guys think?
Old May 18, 2013 | 06:13 AM
  #64
427 fordman's Avatar
427 fordman
Sam, I thought you put a mechanical gauge on the hpop?
Old May 18, 2013 | 08:11 AM
  #65
sleepyhead416
It don't take much of a oil leak. HPOP are LOW volume HIGH pressure. My leak was just a dribble out of injector. But would build NO Pressure out of right side of motor.
Old May 18, 2013 | 06:02 PM
  #66
strokin'_tatsch's Avatar
strokin'_tatsch
I had leaks from 7 of the internal mid body o-rings along with a completely failed external o-ring that was dumping HPO into the fuel system.. FYI, it ran like that for weeks til I fixed it..
Sam, if the IPR hasn't changed anything, unfortunately, you probably need an HPOP. Are you making sure the rez is staying full? With a full HPOP rez, it won't build more than 125?
Old May 18, 2013 | 07:06 PM
  #67
95_Dually's Avatar
95_Dually
Darin, the oil gauge is installed in the ICP port at the moment.
Travis, I double checked the HPOP res afterwards and it is full. I had hoped that the res was low...LOL
Something else that I think is odd is that the heads don't have a lot of oil on them either. My small fords and chevys always made a mess with the covers off while cranking. I know the LPOP is not 60PSI, but I sure thought the heads would have more oil in them. IDK.
I guess I will replace the HPOP then. I want to pull the injectors to check them, but the fuel bowl is CLEAN! The crazy part is since I have it this far apart, I want to install stage 2's and a S366.
Old May 18, 2013 | 08:44 PM
  #68
pjwoolw's Avatar
pjwoolw
So just so I have this straight. There is a gauge of some sort in the ICP port. Was the ICP sensor disconnected from the wiring harness during your test?
Old May 18, 2013 | 08:54 PM
  #69
95_Dually's Avatar
95_Dually
I have a mechanical 5000 PSI gauge in the ICP port. I had it installed in the 3rd port on the passenger side head and only read 125PSI.
The ICP is not plugged in at all...should it be?
Old May 18, 2013 | 09:07 PM
  #70
oldbird1965's Avatar
oldbird1965
The motor will run with the ICP disconnected. The PCM will default to a standard range of hpop pressures. I don't know why you couldn't at least test hpop psi there but it probably would be better in another port.
Old May 19, 2013 | 07:26 AM
  #71
427 fordman
I think I'd test it right off the hpop. I don't know if it matters, but I'd try that.
Old May 19, 2013 | 07:29 AM
  #72
sleepyhead416
You need to block off 1-head ck pressure. Then block off other head ck pressure so you can figure out what side is leaking. Have you checked pressure from HPOP with 1 of line blocked? (Hoses not connected to head)?
Old May 19, 2013 | 05:39 PM
  #73
95_Dually's Avatar
95_Dually
I will have to look at the hpop res and see where I can install the gauge. I am not sure where the leak would be occuring though. At the injector O-rings?
Old May 19, 2013 | 06:27 PM
  #74
427 fordman
Sam, can you just hook up to the hpop line or hpop itself to see if its building pressure? Then try each head one at a time?
I don't think I'm leading you astray..
Old May 19, 2013 | 09:14 PM
  #75
95_Dually's Avatar
95_Dually
I will look at it tomorrow. Lots of things going on at the same time here.
