HAVING TRANNY ELECTRICAL ISSUES!!!!!!
Old Mar 31, 2013 | 03:30 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
No, it's actually sort of pear shaped.
Old Mar 31, 2013 | 03:35 PM
archer_ski's Avatar
archer_ski
Hey guys, I wanted to say thanks for ALL the help. Turns out it was the ground wire on the wiper motor that was giving me hell. But I got it fixed now so everything is good to go. OH! And the earth is actually shaped like texas lo (at least the important partsl
Old Mar 31, 2013 | 04:50 PM
85lebaront2
Glad you got it fixed. With the frame tab missing from the battery ground cable the only ground on the truck is the one on the wiper motor. What you probably were getting was a ground through the shift linkage and when you put it in drive it moved enough to break the circuit. I would go ahead and add a frame ground as some stuff only grounds to the frame at the back. If you have one of the universal ground cables it will have a small pigtail with a crimp splice that is empty. You can get a ground wire off something else and attach it to the body. 1992-96/7 trucks have this already.
Cg willie Willie
35
Jun 25, 2017 10:04 PM
rangergirl94
33
Jan 5, 2013 07:18 PM
0351mike
Dec 10, 2009 07:43 AM
jokerswild
Sep 12, 2007 05:47 AM
illuminance72
Electrical Systems/Wiring
Mar 4, 2004 10:14 PM
