Dim lights
Old Sep 11, 2007 | 11:11 PM
jokerswild's Avatar
jokerswild
Dim lights
86 F-250 351w. Dash lights are very dim, has new hdlight switch. when driving headlights will flicker, radio (am/fm/cd) will cut out but come back on with out having to turn back on. Alternator is new and has been checked, all grounds under hood have been cleaned.
Old Sep 12, 2007 | 05:47 AM
Chiefrider007's Avatar
Chiefrider007
When did this problem start? Is it one spot on the dash or all of it? By flicker do you mean go off and on? I would start off by checking all the wires to the alt. batt., starter sol., volt. reg if equipped, and the fuseable links that most power runs thru. Also on starter and grounds. All wires need to be clean and tight on both ends. This won't cost anything but some time and elbow grease and needs to be done anyway. If this doesn't stop then let us know..
