HAVING TRANNY ELECTRICAL ISSUES!!!!!!
Old Mar 26, 2013 | 04:30 PM
archer_ski's Avatar
archer_ski
My 86 f150 with a 351w is running a C5 3 speed transmission. But I'm having an issue. Every time I put it in drive and hit the gas I lose ALL lights. head lights, tail lights, dash, and radio. But it's ONLY in drive . Reverse, neutral, or parked, I can hit the gas all day and nothing happens. I have ran out of ideas on what it could be . I need help in a BAD way. Any info could be useful. Thank y'all for reading this and thanks in advance for any comments I get.
Old Mar 26, 2013 | 07:13 PM
ctubutis's Avatar
ctubutis
What have you investigated/tried to do to find the problem?
Old Mar 26, 2013 | 07:44 PM
archer_ski's Avatar
archer_ski
I've tried a new alternator, fixed all wires I could find that were chaffed, new steering wheel cloumn, checked the head light switch, new speedometer cable (figured why the hell not), and gonna put a new instrument cluster in next week.
Old Mar 26, 2013 | 08:19 PM
ctubutis's Avatar
ctubutis
I would go investigate and probably clean the kinda thick wires on the Battery + side of the starter solenoid, all power comes from there.
When did this problem begin? My first thought is at the ignition switch on the column....
Old Mar 26, 2013 | 08:32 PM
archer_ski's Avatar
archer_ski
I honestly dont know when it started. I bought it when I was deployed and had my wife and our "mechanic" (very loose definition) all I was told was the radio cuts out. I already replaced the column and the wires are all new.
Old Mar 26, 2013 | 08:39 PM
ctubutis's Avatar
ctubutis
I'm not suggesting replacing the column, or replacing anything... I'm suggesting that might be a place to start your troubleshooting & diagnosis since there is electricity there that controls much of that stuff, and it's an opportunity to have messed something up to have created this problem.
We here are generally not ones to throw parts at problems and hope for a fix....
Old Mar 27, 2013 | 08:37 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I would check and see if the ground from the engine to the body is either loose or missing. The original ground cables on these trucks had a "flag" where it attached to the frame, them goes to the engine block. There is another smaller ground wire from the back of the driver's head to one of the wiper motor attaching bolts (the one with the stud).
BTW, you should have a C6 with a 351W.
Old Mar 31, 2013 | 08:57 AM
archer_ski's Avatar
archer_ski
Hey y'all sorry I haven't replied sooner. Been on vacation, but I'm about to go recheck my ground wires and everything and make sure checks out again. Thank you for y'alls input on this. I dont like throwing parts at this either but I couldnt find any help or anyone who knew what was going on. And it's good to finally know what tranny I have too, it was sad whenever people asked me and I had no clue.
Old Mar 31, 2013 | 09:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by archer_ski
My 86 F150 with a 351W is running a C5.
C5 is a 'tweaked' for emissions C4, was not used behind 351W's. 300 I-6, anemic 255 and 302 only, trans pan has 11 bolt holes.
351W: Your truck should have a C6, Certification Label TRANS code K, trans pan has 17 bolt holes.
Old Mar 31, 2013 | 09:59 AM
archer_ski's Avatar
archer_ski
Haha like I said, I had no clue what it had. I was over seas when my wife bought it and I'm trying to learn as I go. Someone told me it was prolly a C5 so thats what I went with
Old Mar 31, 2013 | 10:07 AM
NumberDummy
Someone told me it was prolly a C5 so thats what I went with.
Uh huh, 'Someone' is clueless. People back in the "Dark Ages" claimed the earth was flat and the moon was made of green cheese.
Who would believe that hogwash today? Chris (ctubutis) maybe, no one else.
Old Mar 31, 2013 | 10:10 AM
archer_ski's Avatar
archer_ski
Lol fair enough. Hey im trying to check my ground wires at the moment but the only wire coming off my block is going to my battery. Is that right or should it ground out to the frame as well? (Like I said learning as I go lol)
Old Mar 31, 2013 | 11:17 AM
85lebaront2
There should be a tab on that cable that goes to the frame near the suspension cross member. It the cable has been replaced (very likely) the aftermarket cables lack the tab. Ford has discontinued the original cable. I used a short starter cable to go from the block to the frame. you can see it in the first picture along with the broken tab on the original ground cable.
There should also be a black ground wire from the back of the driver's side cylinder head to the wiper motor mount. The wire in the circle is a 1986 ground lead. This was during the process of my conversion work so it is a 1990 wiper motor even though it is a 1986 F-350. The engine is a 460 so it is a bit bigger than your 351.
Old Mar 31, 2013 | 11:55 AM
archer_ski's Avatar
archer_ski
Thanks for the pictures, makes it a lot easier to see what im looking for
Old Mar 31, 2013 | 01:40 PM
The Masked Rider's Avatar
The Masked Rider
HOLD ON there Bill. Are you telling me the world IN NOT flat...? ;o(
