The link stated that they had no base/LPOP pressure. It was determined that the LPOP was bad and it was replaced along with a new pump and front cover.
That restored the base pressure but no HP. And then it goes on from there.
We don't know if there is a HP problem until the low pressure is restored.
The LPOP is self reliant. Meaning it operates on its own.
The only other obstruction from the LPOP and the filter housing is the oil cooler. Oil needs to make it through the oil cooler first before it enters the filter.
Barring a major catastrophe, the oil cooler may collect some debris but not neccessarily obstruct totally.
So I maintain that you could remove the HPOP, the stc, feed tube, oil rails, injectors, rocker arms, pushrods, and set them along the side of the truck, and if the LPOP system is working properly, it will pump oil to the oil filter housing.
So what can we do to get the base pressure working again for this guy.
Did you do anything to the engine just prior to the no start such as change the oil and or filter?
There are a couple of things of issue here:
1. Make sure you have oil registering on the dip stick.
2. Interval of oil change. How often and what oil/filter did you use?
3. How many miles on the truck?
4. There could be an obstruction in the pickup.
5. Pick up o ring may have gone bad causing sucking of air.
6. Oil pump got damaged or is worn from high mileage or maintenance issues or particles in the system.
7. Also when you put the regulator back in could you start it by hand or did you have to force it in with much effort to catch some threads?
This is important as there could be a burr or a small obstruction you may have missed that is holding the regulator from going in all the way like it should at rest.
Either way, oil pump is probably easiest to inspect than pulling the pan down while still in the truck.
This is sound advice. I am also having problems connecting the dots on how a leak in the HPO system could affect the LPOP's ability to push oil into the oil filter housing.
I swear I had one that a HPO problem let the Oil just run threw the system so fast that there wasnt enough LPO to get a Reading (In this case they had Oil at the FILTER though)
Regaurdless there MUST be Oil Flowing to the Filter
Since the Poster Did NOT have any sign of oil at the filter the LPO System NEEDS to be ADDRESSED FIRST
Any progress on the LPOP geting pulled for a Look???
The way I read that schematic is the oil must go through the filter housing before it can get anywhere else. So even if there is a leak in the HPOP you should still see oil going through the filter housing. I could be wrong though. Maybe it's going through and you just can't see it.
pulled lpop cover, gear destroyed small pieces and hole pieces of needle bearing all inside. mechanic said lifter came apart said engine replacement only option.
Run6.0run did one also but my thread was alot shorter.
Both have great info on total rebuilds.
If the lifter went, which sounds like it, the cam will need to come out which means the engine also will need to come out. So either way the engine is coming out.
So why not rebuild the one you have while it's sitting there for a big savings? That is if the block is not damaged or the pistons and cylinders are ok.
But still a look see at what you have once it's out is worth a look before deciding a new engine is in order.
This way you can also do the upgrades needed to make this engine is more dependable and reliable.
My total cost was around $2,700.00 for the parts and service done on the heads and cam. Big difference if you can do the work yourself.
Not to Hijack the thread, but with quite a few of these threads popping up about lifter failure, what is the cause of this? Is there anything that can be done to prevent this or is it just dumb luck? Or perhaps your engine was manufactured on a Wednesday and the guy torqueing the rocker arms was dreaming about the weekend and didn't do a good job?
