fuel pressure
Old Nov 9, 2004 | 01:57 AM
94 1/2 stroker's Avatar
94 1/2 stroker
fuel pressure
On a 94 PSD what is the fuel pressure supposed to be at idle? Thanks for the info!!
Old Nov 9, 2004 | 04:49 AM
Crumm's Avatar
Crumm
Around 36-45psi stock. I have mine shimmed to 74psi. You shouldn't go over about 80 at idle.
Old Nov 10, 2004 | 10:11 AM
94 1/2 stroker
What is the shim you are talking about? Thanks
Old Nov 11, 2004 | 12:48 AM
Crumm's Avatar
Crumm
The following is from Steve Baz's website but he doesn't mind sharing. He has tons of information on his site if you want to check it out click here.
Get a regular BB, wait till your engine cools some and take the black cover off the top of your motor. This requires a 1/2 in deep socket and ratchet. There are 3 nuts on the cover. Next look at your fuel filter bowl and just to the right at the front will be a brass 19 mm plug on the fuel regulator. You will want to place a rag below this plug in case you drop anything. Next, remove the plug and place it on the top of your fuel filter housing using a 19 mm socket or wrench. You will now see a little spring that is exposed. Take a pair of small needle nose pliers and grasp the spring and pull it out of the regulator. Place it by your plug noting the way it came out. You will want to go back in with the same end that came out of the regulator side. Next, take a pencil tip magnet and be sure everything is clean on the magnet (we don't want metal shavings in there)....place the tip of the magnet in the hole and it will pull out the little tri-angular plunger that regulates the fuel pressure. Take the plunger off your magnet and look at the end of it. The end that has the hole is where you want to place the ball bearing. Take your ball bearing and drop it in the hole. When I did it the ball just fell in the hole. Take a little punch and make sure that it seats in the counter bore of the plunger. Not with a hammer, just pushing on it by hand will suffice. Next, make sure everything is clean and place the spring back in the plunger the way it came out. Place the plunger back into the regulator. The tri-angular shape will "FIT" into it's respected groove. DO NOT FORCE IT. Turn the plunger until it slides right in. Next, take the 19 mm plug and coat the o-ring with some oil or light grease so you will not damage the o-ring. Next, note the nipple on the end of the plug where the spring is centered. Be sure to get that nipple into the hole on the end of the spring or you will bend the spring and you have trouble. Push the plug toward the threads in the housing as it will be harder to push now, and screw your plug back into the regulator. DO NOT CROSS THREAD THE PLUG. Next tighten the plug back down snug.
I didn't get quite enough pressure to suit me with the bb so I used a small allen screw head. The shaft of the screw fit inside the spring so it all stays put quite nicely.
