2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 Expedition problems HELPPPPP!!
Old Apr 24, 2013 | 11:06 AM
  #76
berry1234's Avatar
berry1234
Any updates?
Old Apr 24, 2013 | 02:24 PM
  #77
jamull2852's Avatar
jamull2852
No I haven't heard from him since last Wednesday or Thursday. We left for Disney world Friday morning so I haven't really cared about it to much while on vacation but since we got back from the parks early today ill give him a call.
Old Apr 24, 2013 | 02:34 PM
  #78
jamull2852's Avatar
jamull2852
K just got off the phone and he said he still hasn't found the problem. He said some of the motor mechanist he deals with said it could be a slug problem but he said that's not it. He said he found two plugs behind the VCT solenoid? That he can blow through and put a tag on the other end to see if theirs any trash but other than that he don't know what else to do. Not sounding good for me. Said the program he uses everyone is mentioning a new motor which I hope it don't come to that. Any suggestions ?
Old Apr 24, 2013 | 02:44 PM
  #79
berry1234's Avatar
berry1234
Post the specifics on flat rate tech.com under the Ford section. Many current and ex-employees post here. Maybe they can shed some light. I have heard of oil starvation problems in the 5.4L when you get up in miles, but I never saw what exactly caused the problem. Most had a rattling at idle then stalling with very low hot oil pressure.
Also, post the same question Mechanical /Maintenance Forum - Bob Is The Oil Guy
There is an expert on the 5.4l mod motors. He may know what's going on.
Old Apr 24, 2013 | 07:02 PM
  #80
jamull2852's Avatar
jamull2852
Ok thanks berry ill post to them later tonight when I get free time.
Old Apr 24, 2013 | 07:16 PM
  #81
JWC 3's Avatar
JWC 3
Butting in ... Jasper has a sales pitch . Oil pump issues in these engines . Claim to have a fix ! ??? Just saying !
Old Apr 24, 2013 | 07:25 PM
  #82
jamull2852's Avatar
jamull2852
You confused me with this last post, what do you mean clam to have a fix?
Old Apr 24, 2013 | 08:22 PM
  #83
JWC 3's Avatar
JWC 3
I can't find the flier they sent me . Had to do with noise , clatter , phaser issues . Had to do with oil pump problems . I , am unprepared . I just had , read it ! I will look more.
Old Apr 24, 2013 | 08:34 PM
  #84
jamull2852's Avatar
jamull2852
Oh ok, ill double check with him to make sure he didnt over look the pump.
Old Apr 25, 2013 | 08:23 AM
  #85
jamull2852's Avatar
jamull2852
Could it be a VCT solenoid be bad? I'm not to sure how it works but I'm trying to do as much research on my phone while on vacation.
Old Apr 25, 2013 | 09:58 AM
  #86
berry1234's Avatar
berry1234
Many people who thought their VCT solenoid was bad eneded up needing replacement engines due to low oil pressure. I can't recall more specifics, as I have not read these threads in a few years.
Old Apr 25, 2013 | 10:01 AM
  #87
jamull2852's Avatar
jamull2852
That don't sound good. He's waiting on his parts guy to come in to see if he has a fitting to fit the plugs to blow out the last two lines he sees. He said he put in a WIX filter I think the name was. I just find it funny that it just started right after he changed the plugs, COP, and oil in it
Old Apr 25, 2013 | 11:16 AM
  #88
jamull2852's Avatar
jamull2852
Ok he said he's removed the solenoid and he's only seeing two screens in it and looks like their should be three so he's doing some research on how many it has and if their is three where did the other one go, so I'm guessing if their is three this could be causing the plugage and could be our problem. Said he called the dealership to see if they can tell him how many screens and they couldn't answer him. Ill keep updating.
Old Apr 25, 2013 | 11:27 AM
  #89
jamull2852's Avatar
jamull2852
Ok nvm he called back and said it should only have two screens and e wry thing is spotless with it. Said he's going test the solenoid and double check its operating like it should. Now if this is bad will it cause no oil to the passenger side of the motor?
Old Apr 25, 2013 | 11:52 AM
  #90
berry1234's Avatar
berry1234
Not sure but it worries me he doesn't know. I hope he is giving you a break on his labor as he seems to be doing a little on the job training.
Has he checked the oil pump?
Read these too. Similar situations.
No oil making it to one side of engine, 5.4L - Ford F150 Forum
No oil pressure on 5.4 Triton - F150online Forums
08 5.4L low oil pressure when hot - F150online Forums
