2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 Expedition problems HELPPPPP!!
Old Apr 6, 2013 | 01:09 PM
  #31
jamull2852's Avatar
jamull2852
It's not real loud but I can hear it from the driver seat with the hood closed. Sounds like a small diesel motor. Sound is def. coming from passenger side towards the front of the motor. That's why I was thinking the timing chain guide. I'm not sure a sound clip will get it clearly and then I don't know how to post it. If it were the injectors will the injector cleaner help or stop the noise?
Old Apr 6, 2013 | 01:37 PM
  #32
berry1234's Avatar
berry1234
No I don't think it will help.
Old Apr 6, 2013 | 05:40 PM
  #33
jamull2852's Avatar
jamull2852
Try this video and see if it works for you. I did it on my phone the best I could.
Old Apr 6, 2013 | 05:57 PM
  #34
berry1234's Avatar
berry1234
That sounds like a lifter to me.
Old Apr 6, 2013 | 06:41 PM
  #35
jamull2852's Avatar
jamull2852
What causes the lifter? And how hard to change?
Old Apr 7, 2013 | 03:52 AM
  #36
jamull2852's Avatar
jamull2852
And could the work I just had done (all new coils/spark plugs) cause any of these problems. If so, can you explain how? Im not good with motors and try to do as much research as poss. to before bringing to the mechanic. Id like to know what to expect and try to make it seem like I know what Im talking about so I dont get screwed to bad.
Thanks Berry
Old Apr 7, 2013 | 04:10 AM
  #37
jamull2852's Avatar
jamull2852
Im also reading alot of people putting 15w40 and getting rid of the ticking noise. Anyone here tried that with any luck? Im driving to Disney World in 15 days in this expedition and would like to have it running like it should before then and not worry in back of my mind if ill make it their without any problems.
Old Apr 7, 2013 | 01:08 PM
  #38
jamull2852's Avatar
jamull2852
anyone....anyone...bueller...anyone?
Old Apr 7, 2013 | 03:12 PM
  #39
berry1234's Avatar
berry1234
Might be worth taking it to a mechanic you trust. That ticking sounds different than the cam phasers noise.
Old Apr 7, 2013 | 03:38 PM
  #40
jamull2852's Avatar
jamull2852
I brought it to my mechanic and he said the same thing that it could be the chain guides bc he's seen a few 5.4's with broken guides. I plan on bringing it in Tom. So I guess ill keep you updated as to what he finds, hopefully it's just the guides bc I already bought the new kit lol
Old Apr 10, 2013 | 12:14 PM
  #41
berry1234's Avatar
berry1234
Any updates?
Old Apr 10, 2013 | 01:48 PM
  #42
jamull2852's Avatar
jamull2852
He actually just called 5 mins ago and said he tested the oil pressure and it was running 50-60 but I think it's suppose to be 70ish? But he also said it sounds like the lifter bc it's from the middle of the motor and still troubleshooting it before tearing into it. He said he's reading that some mechanics have had to replace the motor because of the sound, which I hope we don't have to do bc the truck is in great shape and I'm not sure what a motor cost.
Old Apr 10, 2013 | 02:31 PM
  #43
berry1234's Avatar
berry1234
The oil pressure is fine if that's a warm reading. When it starts getting below 20psi warm then you have issues. You don't need to replace the motor for a bad lifter. I had a collapsed lifter on my 2008 with 7K miles. They replaced the head and it fixed it.
Old Apr 10, 2013 | 03:16 PM
  #44
jamull2852's Avatar
jamull2852
So what's all involved in a bad lifter or to change it? What kind of price is that looking at. I know it depends on the mechanic but just a round about.
Old Apr 10, 2013 | 03:25 PM
  #45
jamull2852's Avatar
jamull2852
Yah he was just saying on the mechanic forum or program he uses he's read a few people having to replace the motor because of the noise not the lifter. He said if its the lifter he can fix it and just saying it can be worse. Sorry for the confusion. Thanks for all your help Berry. Ill update as he calls
