trans slipping?
Old Mar 18, 2013 | 11:37 AM
BRay09's Avatar
BRay09
trans slipping?
06 f250 6.0l
Been having this issue with my trans here and there. While driving from a stop, it'll shift fine through the gears. Other times, it'll shift 1-2 fine (or 1-3), can't remember, but first 2 (or 3) gears will shift firmly, then it feels like it slips into the next. Trans fluid is bright red still, made sure of that when I had my cab off for head studs and gaskets. Nothing smells burnt. No codes. 77000 on it, but to my knowledge it has never had a trans flush or filter internal or external. I'm planning on dropping the pan this weekend and putting a new internal and external filters. Should I get it flushed after this? Or is there something else I can look at as to why this is happening?
Old Mar 18, 2013 | 12:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Try new fluid first.
Old Mar 18, 2013 | 12:50 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
No need to change the internal pick-up.... It isn't a filter. Just clean the magnet.
Josh
Old Mar 18, 2013 | 01:01 PM
BRay09's Avatar
BRay09
How many quarts is it?
Old Mar 18, 2013 | 01:04 PM
Bullitt390's Avatar
Bullitt390
About 8 quarts for a dump and fill.
Mercon SP or LV only.
Josh
Old Mar 18, 2013 | 03:00 PM
Unrealo4's Avatar
Unrealo4
If you wanted to be hard core. You could buy the internal filter for a 2008+. Ive heard they updated them with filter media inside. Other then that they are the same.
Old Mar 18, 2013 | 03:04 PM
Bullitt390's Avatar
Bullitt390
You have to use the 08+ pan with the 08+ filter
Josh
deano-was-his-name-o
Sep 10, 2013 07:09 PM
pile_53574
Sep 28, 2012 07:54 PM
robjs111
1997 - 2003 F150
Nov 16, 2009 04:53 PM
James E
Computer Chips & Tuners
Oct 17, 2009 02:15 PM
wolson
Sep 30, 2003 03:06 PM
