1996/97 E350 7.3 psd start / glow problem
Old Mar 17, 2013 | 04:56 PM
John Inge Nordfonn's Avatar
John Inge Nordfonn
This is a rather long story made short.
I got this car with a problem. The pcm relay was clicking like mad. Changed relay but noe help. Last owner had a Edge programer on it and then the problems started.
I have now changed the pcm and the clicking stopped. I can also pull codes now. I get code 476 back exhaust pressure error.
Engine will not start. Wait to start light comes on and goes out in 5-10 seconds. But i notised that the glow relay stays on with 12 volt to plugs all the time. Engine crancs but will not start.
The car has not been used for 6 mounths now.
What to check next.? Hpop oil ?
Old Mar 17, 2013 | 06:03 PM
427 fordman's Avatar
427 fordman
With the key on, the gpr should have power to both posts for up to 2 minutes.
Check out this chart
http://api.viglink.com/api/click?for...13635614853644
Old Mar 18, 2013 | 06:00 AM
John Inge Nordfonn
Thanks.
I got it running but i had to crank for up to 10 seconds. Its realy slow to start.
Does anyone know where the left impact sensor for airbag is located.. Mine is demounted from last owner and i cant seem to find the place for it.
John Inge Nordfonn
Posted same thing twice. sorry
Old Mar 18, 2013 | 09:04 AM
farmert's Avatar
farmert
Originally Posted by John Inge Nordfonn
Thanks.
These trucks don't have airbags.
Old Mar 18, 2013 | 12:20 PM
John Inge Nordfonn
What.? Yea it has 2. Passenger side and in steering wheel.
I found the right place for it. Center of radiator support.
I got it running and it ran great. But its werry difficult to start. Even more so when its been driven for 10 minutes. Where to look for problems. It gives me no codes but one
P0603 Internal Control Module KAM Error
Reset pcm but stil want start.
Old Mar 18, 2013 | 03:09 PM
farmert's Avatar
farmert
My bad, I see you are working on an E series. The F series don't have air bags.
akpolaris2
Nov 25, 2018 08:43 PM
Nick18
Jun 20, 2010 10:06 PM
Combat Engineering
20
Feb 28, 2010 08:59 PM
chris lacosse
Oct 31, 2006 06:49 AM
northernlights
Jul 23, 2006 12:35 AM
