IDI Pyrometer
Old Mar 16, 2013 | 08:39 PM
bgab3's Avatar
bgab3
IDI Pyrometer
I plan on turning up the pump on my 88 7.3. I have been looking at the Auto Meter 5744 http://www.autometer.com/cat_gaugede...gid=2685&sid=7
What wire do I use for the (to dash 12V (+) Lighting), is that key on power? There is also a wire (Red to switched 12V (+) positive), which wire do I use for this. I would like the lighting for the gauge to be tired into the dimmer with all the other factory gauges. I plan on putting the probe on the driver side just before the flange. Thanks in advance!
Old Mar 16, 2013 | 08:56 PM
hairyboxnoogle's Avatar
hairyboxnoogle
For the light, find a brown wire in the dash, iirc that is the dash lights. Check with a test light first obviously. For the key on, cant help ya, didnt think it would need one.
Old Mar 16, 2013 | 09:33 PM
Phy's Avatar
Phy
I found my ash tray light & followed it back to a convenient spot to tap in.
Old Mar 17, 2013 | 12:01 AM
tecgod13's Avatar
tecgod13
No, thats wire you want to tie into the dimmer switch. Like has been mentioned find a wire running to one of the dash lights. I ended up splicing into mine just after the dimmer switch, but I can't remember which color it was, you can use a voltmeter to probe the back of the dimmer switch and see which one changes voltage when you turn the ****.
This is the one you want key on power. For some reason I think I tied into the wiper switch for that wire. There are several other possibilities though.
Old Mar 17, 2013 | 08:24 AM
bgab3's Avatar
bgab3
Makes sense, thanks!
vwfreak
Nov 6, 2013 06:21 PM
B846B
Feb 1, 2013 04:04 PM
Ringwood1
Dec 4, 2010 10:51 PM
GEugeneS
Sep 14, 2009 09:16 PM
01stroker
May 12, 2007 04:53 PM
