Spark plug repair kit
Old Mar 15, 2013 | 06:46 AM
HD RULES's Avatar
HD RULES
Has anyone checked this out? Seems simple enough.
Old Mar 15, 2013 | 06:10 PM
wpnaes's Avatar
wpnaes
Looks easy enough, lets see if it holds.
Old Mar 15, 2013 | 06:26 PM
Dales77's Avatar
Dales77
the best way to repair a blown out plug is the helicoil kit with tap and insert.. Do Not get the kit that has the drill bit and guide or your truck will never run right again!!!!
Old Mar 15, 2013 | 06:28 PM
Dales77's Avatar
Dales77
The Dorman kit is terrible your truck will never idle right again!!!! The Helicoil kit is the way to go!!!!
Old Mar 15, 2013 | 08:03 PM
Tom's Avatar
Tom
So which is it? This kit doesn't have a drill bit and guide...
Old Mar 15, 2013 | 08:08 PM
wpnaes's Avatar
wpnaes
Do you speak from experience? No offence, just trying to get good info.
Old Mar 15, 2013 | 08:15 PM
Stewart_H's Avatar
Stewart_H
That's a negative Ghost Rider....helicoil is NOT the best way to repair a blown plug.
The BEST way is to use a threaded insert.
Stewart
Old Mar 15, 2013 | 08:19 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Settling in for the ride....
Old Mar 15, 2013 | 09:00 PM
Stewart_H's Avatar
Stewart_H
Here's the difference between helicoil and an insert from one of my previous posts (edited version of my post):
Originally Posted by Stewart_H
It failed because Helicoil does not work on these applications. Helicoils just don't hold well in these Ford aluminum heads.
This is a helicoil. A coil inserted into the old plug hole, creating theads.
An insert, like Timesert, is a solid threaded bushing that mounts in the hole.
Yep, Ford dealerships have done quite a few. Do you know what was used before Lock-N-Stitch became the Ford Motor Company approved way of fixing spit plugs?
Dealerships would use a different insert, like Timesert.
Lock-N-Stitch really are excellent inserts, but if you don't have the cash for them, you can use a Timesert too.
Change your plugs on a cold engine and torque the plugs to 12 to 14 ft lbs of torque.
Stewart
Here's the TSB: http://www.locknstitch.com/FT%20pdf%...20Bulletin.pdf
Spark Plug Thread Repair Inserts
Stewart
Old Mar 15, 2013 | 09:24 PM
Bigpipes 35's Avatar
Bigpipes 35
Stewart
Stewart do you know what the torque spec is for the 03 plugs ?
Old Mar 16, 2013 | 12:09 AM
Stewart_H's Avatar
Stewart_H
12 - 14 foot lbs and you're golden.
I can look it up for you when I get home this Wednesday, if you want the exact, specific spec.
Stewart
Old Mar 16, 2013 | 08:54 AM
HD RULES's Avatar
HD RULES
What's best doesn't matter unless you have the time, place and know-how. Of course there's always the dealer but then you have to have the money. Thought I'd share this since a lot of people don't have either and this looks simple and effective.
Assuming that most people do NOT carry a timesert or helicoil handy in case this were to happen while on that long road trip, this is pretty ingenious and handy for about $50. The Advance Auto has one so I'm going to pick one up.
Old Mar 16, 2013 | 08:57 AM
Archion's Avatar
Archion
Dorman has come up with some nice timesavers over the years. It looks that plug is a 3 valve plug.
Old Mar 16, 2013 | 03:43 PM
Dales77's Avatar
Dales77
The Dorman kit uses an insert that requires a special spark plug and trust me it does not run right with the special plug... The Heli coil kit puts normal threads back in the hole and you use the factory plug a much better fix.... Sorry for not clearing that up sooner...
Old Mar 16, 2013 | 03:48 PM
Dales77's Avatar
Dales77
By the way I have done this on 30+ ford 4.9s and 5.4s over the past 3 yrs and have never had one fail yet!!!!!!
