Frame vin problems
Old Mar 11, 2013 | 06:47 PM
napass2004's Avatar
napass2004
Frame vin problems
I have a bit of a problem I am wanting to register my 61 4x4 and can't seem to find the vin on the frame the one that's supposed to be under the hood is nowhere to be found. The one between the cab mounts had some kind of mount welded to the frame for something welded on and when I cut it off I think I may have ground to much on the frame because its not there either. From all the searches I've found that there should be one right next to the shock mount any one have a pic of where that one should be? Any help is appreciated
Thanks kyle
Old Mar 11, 2013 | 08:26 PM
old broke prospector's Avatar
If it is like my 62 4x4, there is suppose to be a "public vin" plate on your glove box . It is the one the tag agency or police look at for registration (in Oklahoma).
The frame vins are "security vins" and are only looked at if there is a reported problem and then it will be detectives or police looking at them. This is according to the lady at the Tag agency.
On my 62 4x4 the front vin on the frame is very faint, almost readable with chalk rubbed into the letters after wire brushing with a drill. Mine is located passenger side, just behind the front axle area on the top flat area, runs from back to front with a star much like the symbol * on each end of the vin. The stars are very clear, a couple letters are ok, the numbers are faint as if the dies were worn out and the guy was too lazy to go check out new ones.
If no one posts a picture, I will go to the body shop tomorrow take one and post it.
Any time you have a vin welded on you can pretty much bet there is a conspiracy to hide the vin. After you find the correct vin or even if you do not, you can work with your state to get a title update and hope the Communist do not confiscate your truck and impound it until the problem is resolved.
Best of luck
Old Mar 11, 2013 | 08:45 PM
schoo's Avatar
schoo
Is your battery under the floor if so on my 64 4wd the vin # is centered in the bat opening and on top of rail if clean mite be able to read with a mirror
Roy
Old Mar 11, 2013 | 09:38 PM
napass2004's Avatar
napass2004
Well there's no sign of anything where the front axle is and the cab is a donor from a 64 2wd I have a clear title and registration that's past due by 6 years they want 1100 to renew it but they said in California after 7 years it drops out of the system. My only issue is the vin number deal its my own fault for being grinder happy but I just don't want to lose the truck because of it. I could buy stamps and recreate the numbers under the cab but I don't want to cause more trouble for myself if you know what I mean
Thank you guys again
Old Mar 11, 2013 | 09:55 PM
Originally Posted by napass2004
...registration that's past due by 6 years they want 1100 to renew it...
Have you tried a salvage or reconstruction title process where you combine two trucks? Or.... "abandoned" or "storage lien" title? Ask what is the process for taking an abondoned frame and rebuilding it using parts and pieces. It may be cheaper.
Also, If you have a title, I am sure you can order reproduction Ford vin tags with original font and original rivits from the internet. Try http://www.vin-plate.co.uk/index.html If these guys cannot do it, there is someone else in the UK that can and will. Check evil bay.... It will help to have a vin that matches the title on the glove box.
Good luck.
Last edited by old broke prospector; Mar 11, 2013 at 10:14 PM. Reason: added web site to try
Old Mar 12, 2013 | 06:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by old broke prospector
If it is like my 62 4x4, there is supposed to be a Warranty Plate riveted to the inside of your glovebox door.
Where does the OP live? CALIFORNIA not OKLAHOMA, so this info you're passing out is mis-leading, because you are unaware of how things are done here.
CA: DMV/Law Enforcement do not go by VIN's stamped on Warranty Plates, as these plates are too EZ to change.
They go by hidden frame VIN's that have stamped asterisks before/after the VIN / Hidden VIN(s) located atop the right (passenger) side frame rail.
There could be one or two hidden VIN's: Under or partially under the cab, and/or forward of the cab.
Hidden VIN(s) can hard to find due to rust/scale/road grime, and may have been lightly stamped.
Old Mar 12, 2013 | 07:46 AM
Where does the OP live? CALIFORNIA not OKLAHOMA, so this info you're passing out is mis-leading, because you are unaware of how things are done here in CA.
Grumpy, No kidding... Please stop yelling in capitals, it hurts my ears. It is a bit insulting that you imply I am as stupid as a DMV clerk. That is why I stated I live in Oklahoma. I hope every one able to get on the internet is smart enough to know all states are different. People are looking for a way out of title / vin problems especailly after spending a lot of time and money, any examples or hints might help. For example paint the whole fram and really apply a thick undercoat paint over the vin area.
Seriously... does the Calif. DMV crawl unde the the truck or under the wheel well to check the vin or are they as lazy as most of us and just check the visible tag? Is anyone stupid enough to point out their truck does not have a proper frame vin? I hope not.
RANTING Of course it goes without saying it is best to get a title legally in your own state for we must fear and pay our government to screw and control us, even if it costs thousands more in unfair taxes which is what tags and titles are all about. But one can be as creative as the tax man or even take their pickup to another state that is not so controlling and does not check the frame to get it brought up to date and transferred back, it is a simple time and math problem not really worth it unless that is the only way one can get a title and tag without having the truck impounded by the Communist DMV. The last time I was at a DMV (tag agency), a guy did not have his out of state title notarized which was not required in the other state. After the guy was out of earshot, the clerk said she was tired of people not having their paperwork in order. Typical tax collector statement that has forgotten who she serves. RANT Rant rant.
I think I am going to change my handle to grumpy old prospector.
Old Mar 12, 2013 | 07:56 AM
schoo's Avatar
schoo
I live in cal I brought a motorcycle back on "out of system" the hi way patrol does the inspection and they did ck vin in two places
Ford F834
Jun 24, 2012 09:37 AM
Melbatoast
Mar 17, 2011 07:40 AM
F.ROCK
Oct 19, 2008 11:47 PM
dendav
Nov 24, 2003 03:37 PM
Ernie'47
1947 and Older Ford Trucks
Jun 10, 2003 10:08 PM
